Author Topic: 1981 toyota 22R backfiring up the carb..  (Read 4437 times)
chevyLUVtoyota
  • Turtle Points: 60
  • Male Posts: 489
  • Member since Mar '05
« on: Apr 25, 2011, 05:38:43 PM »
i have a 1981 yota with the 22R has a weber carb 32/36 and it runs good tell about 1700 RPM,s and thin starts backfiring up the carb..
dont backfire out the back just up the carb and its over and over not just one time....
i did a dry test and the comp was 150... new coil and all that ... put a diff dizzy in it and still same thing..
new plugs and same thing.....
 :nerv: what do you guys think?
locked 4x4
  • Male Posts: 466
  • Member since Aug '09
Re: 1981 toyota 22R backfiring up the carb..
« Reply #1 on: Apr 25, 2011, 08:45:28 PM »
Whats a diff dizzy???
Rocksnail
  • Turtle Points: 3
  • Male Posts: 595
  • Member since Jun '07
« Reply #2 on: Apr 25, 2011, 08:47:40 PM »
sounds like your timing is off. maybe 180 out. And he means a differnt distributor ( diff dizzy)
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
GreenYoterKrawler
  • Turtle Points: -4
  • Male Posts: 225
  • Member since Sep '10
« Reply #3 on: Apr 29, 2011, 12:24:09 AM »
X2^^^
I blame the automatic transmission for the wussification of America
If Its got tits tires or electronics, your gonna have problems
I drive a jeep cuz toyota doesn't make strollers
laskt9
  • Member since Feb '10
« Reply #4 on: Apr 29, 2011, 07:16:27 AM »
also set lean
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
« Reply #5 on: Apr 29, 2011, 07:50:13 PM »
also set lean
x2 power valve bad?
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #6 on: Apr 30, 2011, 09:26:20 PM »
timing needs to be retarded and quit running gas with ethanol in it.
GreenYoterKrawler
  • Turtle Points: -4
  • Male Posts: 225
« Reply #7 on: May 01, 2011, 05:24:42 AM »
Hey coyote you know anything bout aisin carbs? ive got some issues with idle mixture screw and my choke kickdown.
-sorry for the highjack, any luck with it?
chevyLUVtoyota [OP]
  • Turtle Points: 60
  • Male Posts: 489
« Reply #8 on: Aug 06, 2011, 04:53:52 PM »
It was a flat cam... Put a 3.4 in it.. Now I have 4 cam's whoop
Whoop.. And hallin ass.
« Reply #9 on: Aug 06, 2011, 08:02:50 PM »
sorry, I managed to get one working once by removing the plunger on the fuel cut solenoid but that was all.
Last post Mar 25, 2005, 11:24:05 AM
by Raven
Last post Dec 21, 2005, 07:50:34 PM
by rangerkid
Last post Dec 11, 2007, 04:28:27 PM
by fatt_matt
Last post Nov 14, 2008, 10:25:44 AM
by 4x4yota
Last post Feb 11, 2010, 10:21:49 AM
by 98yota
