Hey man, so what exactly do you want to do make a square drive line for the front? Is your cv out? Honestly it would be cheaper to a) buy a used driveline that's in good condition and build your own or b) get a long spline from marlin and just use a single u joint on it that way you dont have to worry about cv joints I did it and its great.
I'm running a square driveline up front, still using the double cardon joint. It cost me $35 and it has done me justice.
I dont care much for the square DL's if you plan on running 4wd High.... cv at the tcase with a round tube is much better. but to each his own....
Started by Master Yoda General 4WD Discussion
Started by corrupt Toyota Pickup/4Runner Tech 1979-95
Started by booger1 General 4WD Discussion
Started by 82juguete Parts Wanted
Started by MRHilux87 Bumpers, Cages, and Tube Benders
