Author Topic: FJ40 T-case Drive Line Brake Removal  (Read 3551 times)
cmilliron
  • Member since Dec '02
  • I love Marlin Crawler!
« on: Dec 25, 2002, 06:41:40 AM »
My 1973 FJ40 has been converted to disc brakes all around...  I am planning using a cadillac caliper cam as an e-brake.
Can the line brake be removed..???  If so this will free up some serious real estate for installing a  Toy Box...
Cliff
Lodi, CA
« Last Edit: Dec 31, 1969, 04:00:00 PM by 1056988800 »
cruzila
  • Go go cruzila!
  • Hawk
  • Turtle Points: 41
  • Male Posts: 3,848
  • MC20/21 Toybox #002 2.28 = 154:1
    • MTA
Re: FJ40 T-case Drive Line Brake Removal
« Reply #1 on: Dec 27, 2002, 01:15:03 AM »
Do you mean the cable? Or Brakelines?
woody
  • Male Posts: 91
  • IH8MUD
    • IH8MUD.com
« Reply #2 on: Dec 27, 2002, 06:07:00 AM »
Sounds to me like you want to remove the the parking brake drum, backing plate, assembly, etc.  Given that the brake drum fits on the rear output of the t-case much like a yoke fits on the pinion, I don't believe you'll pick up ANY extra length by removing and replacing with a normal yoke.  I do believe however that the drum shaft OD and the spline count is the same as a pinion tho, so you could at least drop a few # of weight there.  Any additional length changes would require an outputshaft modification - shorten, machine down for new locking nut, new seal, possible new rear bearing, etc....more $$ than it's worth.
You'll pick up 3.5" of wheelbase reversing the rear leaf packs.  That's the normal change for added driveline needs.
Brian 'woody' Swearingen ~ IH8MUD Inc.
Last post Oct 19, 2004, 12:20:02 PM
by toyrocs
Last post Dec 23, 2007, 11:47:07 AM
by KYOTA
Last post Aug 11, 2011, 03:04:37 PM
by 4RunnerChevy
Last post Feb 09, 2012, 08:51:14 PM
by Cheesemaker
Last post Jul 13, 2013, 12:27:01 PM
by zembalayan
