Author Topic: full width axle swap  (Read 4549 times)
lil yota
  • Male Posts: 26
  • Member since Oct '10
  • IF IT AINT BROKE FIX IT BEFORE IT IS HAHA!!!!!
« on: Oct 20, 2010, 04:09:52 PM »
just picked up Dana 44 front and 12 bolt rear is there anything i need to know before i do the swap
except rebuild them change gears and up grade anywhere i can any input would be wonderful
DON'T STRESS IT!!!!
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: full width axle swap
« Reply #1 on: Oct 20, 2010, 09:03:13 PM »
Yeah, swap them for a 60 and a 14-bolt.
bigarms23
  • Turtle Points: 111
  • Male Posts: 2,897
  • Member since Jun '07
« Reply #2 on: Oct 20, 2010, 10:00:08 PM »
use skymanufacturings front hanger crossover steering and marlin 4inch springs get your brake lines made and use a gm master cylinder for the 12bolt get the moser c-clip eliminator kit for gears 513s and make sure the pinion caster is 7degrees that should give you a start also what vehicle are these going in for strength add longfield ujoints
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Santa Cruz, CA
    • My YOTA Pics (click here)
« Reply #3 on: Oct 20, 2010, 10:16:22 PM »
u should toss that 12 bolt and get a dana 60 or 70 rear..full floating much stronger and cheap
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
    • Buy me a drink
« Reply #4 on: Oct 20, 2010, 11:56:00 PM »
whats wrong with a 12B? once u do a c clip elim.... what else is the downfall?
im curious to see your spin.
The OP wanted advice and help with swapping the D44 and 12B..
I don't think he asked if he should dump em for 1tons?
lil yota [OP]
  • Male Posts: 26
« Reply #5 on: Oct 21, 2010, 04:49:43 PM »
thank THK can you shoot me a web site for a good  c clip elim that would be awsome
DON'T STRESS IT!!!!
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
  • Member since Feb '05
« Reply #6 on: Oct 21, 2010, 05:18:23 PM »
i ve said it before, and will again, i had a HIGH horse motor =TRIPLE T cases, 40s, 42s, and i wheeled the truck like i HATED IT
it had a 44 with chromos and an arb
the 12 bolt was stock with a spool and 5.38s
the 44 pooped out shafts all the time until i went to chromos, then wasnt too bad, the 12 bolt broke once in 6 years, an axle shaft, and i totally deserved it! i GUARANTEE, I would have broke a rockwell in the same spot.
is a 60 better? yep!
is the 44 and 12 bolt cheap, a dime a dozen, easy to work on, and fairly strong, yep!
 GREAT CHOICE IF YOU PLAN WELL
bigarms23
  • Male Posts: 2,897
« Reply #7 on: Oct 21, 2010, 07:00:31 PM »
i got my c-clip eliminator from www.moserengineering.com or www.summitracing.com offers the moser kit as well ive had mine since 06 and so far so good and im running 37mtrs
« Last Edit: Oct 21, 2010, 07:08:56 PM by bigarms23 »
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Santa Cruz, CA
« Reply #8 on: Oct 21, 2010, 07:53:57 PM »
i race cars at the speedway and i have broke a total of 5  of those c clip elim... so i would not reccomend spinning doughnuts or circle track racing for that matter lol
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #9 on: Oct 21, 2010, 08:06:04 PM »
how fast are you spinning those tires and racing puts a whole different stress on them then crawling.
Pretty sure he isnt going to be doing 6000rpm clutch dumps, or 100mph+ thru a trail.
So that being said, I find no reason a D44 and 12B will fail this guy anymore then any other axle will.
If he had a RamJet 502 V8 or something comparable, I would totally side with you and tell him he will brake 'em.
But I highly doubt he needs 1tons, or he would of stated so.
Sounds to me like he is souly going for the width and stability.
Now I think Lil Yota should post what his vehicle is, make, model, engine, trans, tire size, tcases? and purpose.
That would really help us out.
But like stated, C-Clip Elim, Ujoint upgrade, GM 1 ton Master Cyl, and brake lines made.
you could get away with the 12B drum brakes for now if you're on a budget.
Shed some light on us though Lil Yota
lil yota [OP]
  • Male Posts: 26
« Reply #10 on: Oct 24, 2010, 11:08:36 AM »
94 4runner new engine 2.4 i just bought a w56 and t case to put in during the axle swap i am looking to make it a DD but i also want to be able to take the family out and have fun on moderate trails
DON'T STRESS IT!!!!
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #11 on: Oct 24, 2010, 12:38:35 PM »
DDing with FW's will be fun with law enforcement lol other I think a 44 n 12b will be fine
IronClad
  • Turtle Points: 635
  • Male Posts: 2,284
  • Annihilation Fabrication
« Reply #12 on: Oct 24, 2010, 01:09:00 PM »
i never had any issue as long as i had my flaps on.. so shouldnt be that bad.. and i live in California too
Do you need a Hammer?
lil yota [OP]
  • Male Posts: 26
« Reply #13 on: Oct 24, 2010, 03:58:14 PM »
Well i live in new mexico with no emissions so not to worried boug the law
DON'T STRESS IT!!!!
Last post Aug 23, 2006, 06:44:11 AM
by RCKSQRL
Last post Jul 16, 2007, 07:22:24 PM
by DTB
Last post Dec 20, 2007, 08:09:35 PM
by Oddmar
Last post May 30, 2008, 01:07:04 PM
by Birfailed
Last post May 26, 2016, 08:57:16 AM
by megaphoneman
