Author Topic: Problem starting a 87 Runner (HELP!!!)  (Read 1841 times)
solidaxle007
  • Member since Apr '07
« on: Aug 24, 2010, 06:24:27 AM »
I have a 87 runner and in the past few months its been having problem starting up.  All it does is make a clicking sound from the passenger.  I would have to turn the key several times before it would start up.
I installed a new starter recently as well...
Please help Thanks
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Member since Nov '04
  • Drinking me beer
Re: Problem starting a 87 Runner (HELP!!!)
« Reply #1 on: Aug 24, 2010, 06:26:52 AM »
battery charged?
solidaxle007 [OP]
« Reply #2 on: Aug 24, 2010, 07:19:40 AM »
The battery is good.....
87hillbillyoter
  • Turtle Points: -43
  • Male Posts: 1,066
  • Member since Mar '10
  • git er duuunnn!
« Reply #3 on: Aug 24, 2010, 08:01:37 AM »
check all of your connections-battery terminals, the one on the starter, mine did the same thing and i tightened all of them down now she fires up every time
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #4 on: Aug 27, 2010, 12:02:59 AM »
Sometimes as the ignitions get older this occurs, if this is the case you can put an old style auxillary light relay on it and fix the issue. Just wire the relay as if the ignition switch is the light switch and the other side as if it were the light.
highridin4x4
  • Male Posts: 237
  • Member since Oct '06
« Reply #5 on: Aug 27, 2010, 05:00:41 AM »
Is the clicking coming from the starter? If it is the contacts Inside the starter solenoid are probibly worn out. They arnt hard to replace and can be purchased at napa.
Scott
E YOTA
  • Male Posts: 690
  • Member since Jan '04
« Reply #6 on: Aug 30, 2010, 11:21:13 PM »
theres a relay that controls the starter there in that corner. listen carefully and pull it out...its bolted to the wall there with a 10 mm. that sometimes go bad and is a head ache. best fix is too wire up the starter straight  from the key ignition.... never have that problem again!!
built lastnight, crawl today...
gtoyonrocks
  • Turtle Points: 2
  • Male Posts: 977
  • Member since Dec '06
« Reply #7 on: Aug 31, 2010, 07:31:12 AM »
The contacts in starters wear out. Get some electrical contact cleaner and clean the connect or the starter also. I hope this helps.
solidaxle007 [OP]
« Reply #8 on: Aug 31, 2010, 12:37:29 PM »
Thanks Yall...
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
« Reply #9 on: Aug 31, 2010, 12:41:20 PM »
had the same problem with mine, ended up being a bad wire connector that clips on the starter solenoid.  cleaned it up, sprayed some silicon spray and it fixed it.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
Last post Jun 01, 2005, 03:13:07 PM
by b_ripper8
Last post Jan 23, 2006, 05:05:00 PM
by Zoomschwortz
Last post Oct 19, 2006, 12:00:25 AM
by Wermz84
Last post Nov 19, 2007, 01:54:35 PM
by 4DEES
Last post Nov 28, 2008, 03:09:14 PM
by Nothingface5384
