Author Topic: Tube Bender Plans  (Read 7842 times)
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
Tube Bender Plans
« on: Apr 22, 2008, 05:43:32 PM »
Here is a link for a set of plans to build a really nice bender. I have built this bender and it works great made all the tube stuff on my rig with it. www.gottrikes.com
91 super yoda
  • Turtle Points: -56
  • Male Posts: 400
  • Member since Sep '04
  • Axe' em Jacks
    • Old Town Customs
Re: Tube Bender Plans
« Reply #1 on: Apr 22, 2008, 06:06:56 PM »
im in the market for a bender and this one seems like something i would be interested in. if your going to build one keep the board updated on the difficulty level of the build and if it does whats is advertised.
*ROKTOY* [OP]
  • Male Posts: 1,066
« Reply #2 on: Apr 23, 2008, 10:59:28 AM »
Well I have already built one as stated above. It was not hard to build at all. You will need a drill press with the larger size bits and a good welder capable of welding 5/8" steel. It is an excellent bender and works great I have used it to build my bumper, and flat bed.
89trailrunner
  • Male Posts: 17
  • Member since Dec '07
« Reply #3 on: May 05, 2008, 04:59:53 PM »
i have this bender as well, it does as advertised, plans are very good, built two pairs of sliders, a stinger winch bumper, a regular winch bumper, and working on an exo... if you build it you won't be dissappointed...
yotaboy79
  • stuck in the shop
  • Turtle Points: -19
  • Male Posts: 2,838
  • Member since Aug '03
« Reply #4 on: May 05, 2008, 10:43:15 PM »
i made one that matched the plans it worked good but i wore it out all the holes got sloppy and egged out and the frame started to twist (some parts where made from thinner steel) and it was cobbled togeather.
a wile ago i scraped that one and built another one off of the same basic principal except the die sits about 4 ft tall so your not bending over all the time and the front and back are longer because the old one would all ways tip over with a full length in it. i also used brass bushings in the pivot points and stuck some nice casters underneath it. its currently air over hydro other than being slow i like it, i plan on upgrading to electric over hydro soon.
ROKTOY829
  • Turtle Points: 45
  • Male Posts: 191
  • Member since Feb '08
« Reply #5 on: May 08, 2008, 10:51:19 AM »
Just got my plans for the bender anything ya suggest? do i need to pay attention to anything real close or is dummy proof.
*ROKTOY* [OP]
  • Male Posts: 1,066
« Reply #6 on: May 11, 2008, 12:52:18 PM »
I would check Franks site there are some good tips on there from others who have built them.
brc
  • Male Posts: 139
  • Member since Mar '06
  • Famous last words - Hold my beer and watch this
« Reply #7 on: Jun 26, 2008, 11:35:12 AM »
Built one as well good bender I had all the holes in mine done on a mill thought and cut the side plates and all on it.  Turned out really well the only change I made was to make the bottom tube out of receiver tubing and legs that extend out about 4ft and mounted it all on 1000lb castors to move around easier.  Good plans and good finished product in my opinion.
1999 CTD 2500 Sport TST/MBRP/AFE/K&N and Quadzilla 315's yada-yada-yada
1985 Four runner 5in lift 35's lockers etc.
1973 FJ buggy project INWK 3RZ SM420 Mini Axles and Aluminum tub/cowl building to be light weight
mathwizz90
  • Male Posts: 20
  • Member since Nov '08
« Reply #8 on: Jan 06, 2010, 07:23:37 PM »
What does this one cost to build?
Volcom
  • Turtle Points: 269
  • Male Posts: 2,418
  • Colorado Rocks!
    • http://www.rockfrogs.org
« Reply #9 on: Jan 07, 2010, 11:59:29 AM »
I bought the plans and was planning on building one.  My dad, buddy & and I ended up just buying a JD2 and converting it to air over hydro rather than rounding up all the material to build the gottrikes bender.  It saved us some time but cost us a bit more.  The gottrikes bender looks to be a good design though!
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Last post Mar 10, 2003, 08:24:01 AM
by snorklehead
Last post Dec 23, 2004, 01:04:45 PM
by TrackVino
Last post Apr 18, 2006, 08:32:47 AM
by Rockdiver
Last post Sep 30, 2007, 10:37:16 AM
by ghetto_wheeler
Last post Oct 22, 2008, 06:50:14 AM
by 854RUN
