Author Topic: leaky pinion and t-case seal caused by square driveline?  (Read 2242 times)
donutman126
  • Turtle Points: -1
  • Member since Aug '06
« on: May 08, 2008, 05:20:40 PM »
Well I finished installing my dual cases and my 5.29 gears in the front end about 4 months ago. I built a square driveshaft for it and today while under my truck i noticed the output for the front driveshaft on the t-case is leaking and the front pinion is leaking. Both seals are going to be a real pain to replace and I was wondering if you guys thought my front driveshaft is the culprit?
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
If it is not perfectly balanced, I would bet that the square shaft caused it. :twocents:
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
if your doing more than 20 mph  and its  not a  perfect yes  it will  blow the seals,  and even the bearings
Mnmstoy
  • Turtle Points: 50
  • Male Posts: 230
  • Member since Feb '05
  • Mike's 80Toy
I have ran a front square drive shaft for over two years now. Mine has never has leaked.
Sorry to hear you have that problem.
Mike
of course that is rock crawling...max speed about 30mph here and their out on the trail. mostly, below 5mph lol
donutman126 [OP]
  • Turtle Points: -1
My driveshaft doesnt start vibrating till about 40, and i have only done that once all the rest of the time the front shaft was engaged i never went over 15.
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
I still wouldn't rule it out, since thats the only thing connecting your front axle to your transfercase, and seals at both ends are ruined.
What kind of shaft is it? A CV shaft, or a regular 2 joint shaft? if its a CV shaft, you need to point the pinion flange at the front transfercase flange. If it is a 2 joint shaft, the pinion flange and front transfercase flange need to be on parallel planes. If you don't have the shaft set up correctly, I guess the incorrect setup could also cause seals to fail. :dunno:
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
  • Member since Sep '06
  • out from under my rock, and ready to roll
Are these newer seals or the 20 year ol ones like what I have?
That reminds me when is marlin coming out with the new inproved output seals , to match my front axle inner axle seals?
There are other reasons your seals could be leaking to. The square driveshafts always seem to get the blame,  for stupid problems. What kinda wear is there on your output/input shafts seal surfaces? Na that cant be it it has to be the square shaft....... :blah: My square drive shaft caused my puppies to get hit by a car....I guess I should have seen it coming.  ::) :gap:
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
Jordan7118
  • Turtle Points: -21
  • Male Posts: 1,105
  • Member since May '07
:rofl2:            :werd:
donutman126 [OP]
  • Turtle Points: -1
I replaced both seals when i did my cases and front end.
ROCKO
  • Turtle Points: -49
  • Male Posts: 743
  • Member since Sep '07
  • NOR-CAL WHEELIN
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
Last post Jul 07, 2005, 12:30:36 PM
by paradisekid
Last post Feb 02, 2008, 07:33:33 PM
by Gittinit
Last post Sep 19, 2008, 09:24:36 PM
by Duffil
Last post Jan 31, 2010, 05:30:34 PM
by Yota87Truck
Last post Jun 01, 2013, 03:26:18 PM
by TimberlineBryce
