Author Topic: Flasher location 79 pickup  (Read 5506 times)
WiLdwOrLdOfWiLl
  • Member since Sep '06
« on: Sep 04, 2006, 06:52:12 PM »
I need some help here. I need to know exactly where the flasher and hazard relays are located for a 79 toyota longbed. It has the tach and extra gauges if that matters. I have looked but can't seem to find the right thing. What I have found is a relay that says buzzer on the left side of steering column under dash. Fuel pump relay on right side of column under dash. Two square relays above gas pedal, these are 3 prong but have a real close pattern and do not match ep35 which is what comes up for a flasher. Any help would be appreciated thanks.
Will
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Flasher location 79 pickup
« Reply #1 on: Sep 04, 2006, 06:54:07 PM »
eather in the fuse box, or on the passenger side kickpanel
« Reply #2 on: Sep 04, 2006, 06:55:21 PM »
btw  :welcome: to Marlin  :wave:  where are you located ??
« Reply #3 on: Sep 04, 2006, 06:56:44 PM »
i know when i turn my blinker on its over there on the pass side kick panel that makes the big noise , CLICK,CLICK,CLICK
topar
  • Male Posts: 1,909
  • Member since Aug '06
  • One Toyota + One Mopar = Topar
« Reply #4 on: Sep 04, 2006, 07:03:19 PM »
:welcome: I have an 81 long bed and have two fuse panels one on drivers side kick panel and one on passenger side kick panel (Not sure if this one is factory or not looks like it is).  Maybe you could look on the passenger side.
WiLdwOrLdOfWiLl [OP]
« Reply #5 on: Sep 04, 2006, 07:05:21 PM »
Thanks I will check over one the passenger side better. I looked there but not real hard. I am in Kentucky. I have been into jeeps and this is my first toyota. Anybody got a FSM for as 79 laying around?
« Reply #6 on: Sep 04, 2006, 07:09:18 PM »
just the one sittin on 32's  out in the driveway :dunno:
a haynes is fairly good
« Reply #7 on: Sep 04, 2006, 07:15:32 PM »
Ok I checked out the pass side. It has a wiper control box and another larger box but I dont know what it is??? I did find something that could be the flasher or hazard relays way up under the dash next to the side heat/ac outlets. There is one on each side but the passenger side is 3 prong in a real tight pattern and the driver side is 4 prong. Neither one are like a normal flasher?? I need to go buy a Factory service manual as haynes is pretty vague.
« Reply #8 on: Sep 04, 2006, 07:18:09 PM »
give me a few minutes, i'll go turn my flashers on and try and get a pic of what clicks  :snapshot:    brb :bolt:
« Reply #9 on: Sep 04, 2006, 07:23:37 PM »
ok, i got a pic
« Reply #10 on: Sep 04, 2006, 07:29:34 PM »
 :inthedark:
« Reply #11 on: Sep 05, 2006, 01:16:44 PM »
79Coyote - thanks for all your help. I am going to take mine apart and see if I can figure out if a contact is bad or something. Its like 43 bucks from toyota. Thanks again
« Reply #12 on: Sep 10, 2006, 10:42:30 AM »
OK just to inform anybody who has a flasher go out the pin pattern is different on the factory flasher than any other flasher. So I ordered one through toyota for 45 bucks... and I get the regular style flasher and a short wiring harness converting it over. I think the regular flasher number is ep35 and then two of the pins are used and the third is ground.
« Reply #13 on: Sep 10, 2006, 11:19:46 AM »
so you just got a little can flasher  and a wireing harness??  man that sucks
Last post Feb 07, 2005, 04:58:51 PM
by 79coyotefrg
Last post Feb 07, 2006, 10:48:05 PM
by FatAzzRunner
Last post Sep 04, 2014, 12:05:28 PM
by 81 shortbed
Last post Mar 28, 2017, 07:51:25 PM
by emsvitil
Last post Jul 11, 2024, 05:56:51 PM
by idahank
