Author Topic: front drive help  (Read 1488 times)
crazymoritz97
  • Male Posts: 298
  • Member since Jun '04
front drive help
« on: Jul 04, 2006, 12:01:30 AM »
hey guys or galls
a friend  just bot a 80 Toyota truck with a 4in lift and 33in tire and the front drive shaft is making some funny sounds come from the c.v. joint  is rubbing & bottom of the shaft keeps hitting please help me
\from moritz97
Chris g Moritz
lilbuddy
  • Dried Fruit Warrior
  • Turtle Points: -234
  • Male Posts: 5,720
  • Member since Aug '04
  • Hella....
Re: front drive help
« Reply #1 on: Jul 04, 2006, 12:06:43 AM »
Sounds like the CV is shot. Mine did that and it exploded for the most part. It moved around so much that it actually broke off one of the fins on the transmission.
RIP Kyota.... you are the man
GET IT!!!
notajeep
  • Turtle Points: -108
  • Male Posts: 703
  • Member since Oct '04
  • Crawler #3289
« Reply #2 on: Jul 04, 2006, 06:29:30 AM »
most 80's didn't come with a cv style front shaft. When I first lifted my 80 with the stock shaft I had the same problem of the angle being to much for the yolk of the shaft to clear the u-joint during rotation. So I kinda got a thump thump sound.  I clearanced it with a die grinder so it would operate at the steeper angle, but eventually just replaced it with a cv style shaft.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #3 on: Jul 04, 2006, 08:21:46 AM »
my 79 came witha cv shaft :dunno:
the cv can be rebuilt parts are about $50   if you can change a ujoint you can rebuild it yourself
most likely  its the 4 inch lift,  get yourself some dual cases  and your driveshaft angles will be fixed
notajeep
  • Male Posts: 703
  • Crawler #3289
« Reply #4 on: Jul 04, 2006, 09:17:58 AM »
"get yourself some dual cases  and your driveshaft angles will be fixed"
That is the best solution.
« Reply #5 on: Jul 04, 2006, 10:04:05 AM »
:yupyup:
lilbuddy
  • Male Posts: 5,720
  • Hella....
« Reply #6 on: Jul 04, 2006, 11:04:16 AM »
:yupyup:
Glens proud of his good achievement.
Im mad cause you beat me to it
GET IT!!!
« Reply #7 on: Jul 04, 2006, 11:15:29 AM »
:yesnod:  im prouder than a new papa :woohoo:
:usa:   best mod i ever made to my truck,  better gearing, better driveline angles  :woohoo:
Last post Jan 29, 2003, 12:09:54 PM
by BigMike
Last post Mar 26, 2004, 04:08:29 PM
by yotaboy79
Last post Dec 29, 2004, 06:32:05 AM
by 4runner
Last post Dec 02, 2006, 08:22:09 AM
by rockcrawlinredneck
Last post Jan 02, 2007, 05:10:44 PM
by Trailtoy83
