Author Topic: Twin Stick wont let me shift  (Read 1974 times)
84 Toto
  • Member since Feb '06
« on: Mar 29, 2006, 05:20:27 PM »
I think I may have gotten the wrong twin stick, in 2wd my gearshift knocks the 2wd/4wd shifter into 4wd with 2nd and 3rd gear. The bolt pattern fit and everything but I cant use 2wd, could I have maybe gotten a top shift or v6 shifter.
Techtafab
  • Turtle Points: 48
  • Male Posts: 119
  • Member since Nov '04
Re: Twin Stick wont let me shift
« Reply #1 on: Mar 29, 2006, 05:47:07 PM »
did you take the Dtent balls out ??  :think:
GEARED DOWN CRAWLERS
D-runner
  • Turtle Points: 33
  • Male Posts: 31
  • I love Marlin Crawler!
« Reply #2 on: Mar 29, 2006, 05:48:17 PM »
Sounds like you have a top shift twin sticks on a forward shift t-case.
Adam W.
87 4Runner SR5 - 22RE w RV head & TRD Cam, LCE header, W56HD, 4" Stage II, 1.5" BJS, Rancho T-bars, F 5.29, R 5.29 ARB V6 FF w LC disks, 35" MT/R's
85 4Runner frame, 5" Marlin springs, 5:29 ARB HP front. Work in progress - Always!
Willy Mammoth
  • Male Posts: 4,252
« Reply #3 on: Mar 29, 2006, 06:25:36 PM »
There is an interlock pin or ball that has to be removed so you can move both rails at the same time.
 If you don't take it out you will only be able to use low if you are in 4x4.
This may help http://www.marlincrawler.com/htm/transfercase/twin_stick_inst.htm
84 Toto [OP]
« Reply #4 on: Mar 30, 2006, 03:43:59 AM »
I already did that, it works great and fit great I just cant shift gears.
Willy Mammoth
  • Male Posts: 4,252
« Reply #5 on: Mar 30, 2006, 04:04:20 AM »
After rereading what you posted I see what you meant.
You may need a gasket to lift the shifter up some.
The shifter must be sticking through the rails and hitting the trans shifter rails.
84 Toto [OP]
« Reply #6 on: Mar 31, 2006, 02:34:40 PM »
No the knobs were hitting I called Steve at Marlin and he said to use it on a single transfer case you have to bend the shifter so I heated the 2wd/4wd shifter and bent it back about an inch and it works great now.
  • Administrator
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #7 on: Mar 31, 2006, 02:38:27 PM »
Thats weird. I know you got it fixed, but you should not have had to do that.. There should not be any modifications necessary in order for our Twin Sticks to shift properly. They should work just fine atop a T/case no matter if its a single case or a rear case. I wonder if you have a shifter from a different transmission that is angled differently than your stock one?
Glad you got it fixed, sorry you had to modify it.
Regards,
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
« Reply #8 on: Mar 31, 2006, 03:07:23 PM »
On mine the problem I had when I first put it on was the boot was causing both levers to shift in sync.
Removed the boot, end of problem.
Last post Jun 29, 2006, 08:23:10 PM
by Weldo
Last post Nov 03, 2010, 07:34:48 AM
by runner88
Last post Oct 24, 2010, 05:37:03 PM
by bleakhorizon
Last post Jan 07, 2011, 11:10:30 AM
by motormouth559
Last post Apr 27, 2011, 01:48:49 AM
by bluesboy707
