Author Topic: v-6 rear end upgrade  (Read 1731 times)
jldx4
  • Male Posts: 24
  • Member since Aug '05
  • gopher it
« on: Mar 18, 2006, 04:06:32 PM »
i have a v-6 rear end sitting in my garage, is this a bolt on upgrade for my 86 4-runner,
or do i have to use the guts in the 4cyl. axel? :turtle:
beat @$$ yota
Willy Mammoth
  • Male Posts: 4,252
  • Member since Nov '04
Re: v-6 rear end upgrade
« Reply #1 on: Mar 18, 2006, 04:35:24 PM »
I would have to say it should be a bolt up fit or you could just put the third in the 4cyl housing. You will need to clearance the housing a bit for the third to fit.
If it is an IFS rear it will be wider than a non IFS.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Mar 18, 2006, 04:41:40 PM »
his 86  is IFS  so  yes  it should bolt right in
are you planning on useing the entire housing or just the 3rd??
jldx4 [OP]
  • Male Posts: 24
  • gopher it
« Reply #3 on: Mar 19, 2006, 08:50:51 AM »
i plan on putting new springs on the v-6 rearend and sticking the whole thing under it.
are the gear ratios the same?
thankx for the help!!!!! :turtle:
« Last Edit: Mar 19, 2006, 09:14:57 AM by jldx4 »
beat @$$ yota
« Reply #4 on: Mar 19, 2006, 10:05:27 AM »
that depends,  if both your truck and the donor rear are stock   then most likely yes,
jldx4 [OP]
  • Male Posts: 24
  • gopher it
« Reply #5 on: Mar 19, 2006, 03:58:38 PM »
then its on !!!!!!!!!!!! :beerchug:
beat @$$ yota
89 toy
  • Turtle Points: -1198
  • Male Posts: 383
  • Member since Dec '03
« Reply #6 on: Mar 21, 2006, 12:56:16 PM »
the v6 housing i got had larger center pin holes then my 4cyl housing.
Last post Sep 15, 2005, 02:15:33 PM
by hornett22
Last post Apr 04, 2005, 09:04:54 PM
by krawler2012
Last post Feb 26, 2006, 10:08:31 PM
by MidgetMike
Last post Feb 05, 2007, 08:45:14 PM
by idacurt
Last post Oct 30, 2012, 04:10:08 PM
by RickerRicker19
