look under the hood on the inside of the right fender , there is a tag it should have all thew trucks specs there, axle code, G292, L50, L52 are 5 speeds, L45 is the best 4 speed
if your tranny is the all cast iron L45-52 you have a strong case, and the only difference between the L45 and the L50 is a 5th gear
the 45 is a LOT stronger than the alum bell hoising side shifting L43
