Which is best replacement clutch for 87 22R 5 speed - 1600 or 1200 and why?
You want to use .026" as the step on the flywheel for a little more grip
Remember grip lessens as clutch disc wears (there's less spring pressure). The slightly different step size just gives you a bit more spring compression. Search this site for 'clutch step' 'flywheel step'...…….You don't bother with new flywheel.When you get your old flywheel surfaced, it's 2 passes. First pass is the surface that contacts the clutch plate. They take off minimum amount that will surface the contact area.Second pass is to get the step the correct height. You just tell the machine shop you want .026 rather than whatever the stock step height is.Also measure the before and after thickness of flywheel. Then add washer/shim under fork pivot bolt that's the same thickness as what you lost on flywheel. This puts the fork in the same relative position it was before you machined the flywheel.
Also, I would not suggest the extra step in the clutch. The clutch works much better with the factory step. The increased step does have its benifits, but you lose most of your clutch pedal when you do that. Instead of the clutch starting disengage early on or midway in the stroke of the pedal, the clutch releases almost at the top of the pedal. I personally like having the full range of motion in my clutch.
I don't see how the step would have any effect on the cluch pedal.Once the disk has worn .006", you should be back to "stock" measurements. The self-adjusting slave cylinders should keep everything the same.I can see a self-adjusting vs the older manual adjusting slave cylinders having an effect on the pedal (the self adjusting slave would tend to keep everything constant. The manual adjusting would vary with your adjustment and as the disc wears), and the free-play adjustment on the pedal having an effect...………...
Toyota engineers could have designed the flywheel and clutch system any way they wanted, but they spec’d the step at .020” for a reason.Gnarls.
Toyota engineers were not designing with oversize tires and dual ultimate gearing in mind.
Everyone has different experiences.I agree that it makes sense to modify and change hardware to enhance strength, drivability, and safety.HOWEVER….it’s well-known that the early Toyota pickup and 4Runners are considered - by most automotive enthusiasts – that Toyota’s engineering and design is “over-built” for longevity.I 4-wheeled a basically stock 1985 Standard Cab, 22R, 5-speed for 10 years on the most difficult trails and terrain in California, Utah, Arizona, New Mexico, and Sonora Mexico. Many times I started and finished the trail in front of, or behind, vehicles that were modified and tricked out with 10’s of thousands of dollars. My $5,000 Toyota truck with 33” tires did the same trail as the $50,000 blinged-out-terrain-thrasher with 40” tires with that heavy-duty-rooty-tooty-super-clamping-no-slip clutch! I had one (1) drive train failure in that truck on Pritchett Canyon and it was my careless move that broke the factory stock J-arm. Was I lucky? Was I just a very good driver? Or… was it that the Toyota engineers designed and built it right?As I said, in 20+ years of serious and active 4-wheeling, I don’t recall an issue with clutch discs prematurely failing due to lack of friction and insufficient pressure plate clamping… on any 4x4 vehicle. I have never experienced a premature clutch disc failure on my stock or stock replacement clutch, pressure plate, and flywheels.Gnarls …. My 4 cents worth.
Started by wildchild1066 Toyota Pickup/4Runner Tech 1979-95
Started by milla85 Project Research and Build-Ups
Started by Peterbuilt84 Newbie Questions
Started by dannyv New Member Check-In!
Started by 019854Runner New Member Check-In!
