Advice needed on a transmission problem. I have a 93’ Toyota pickup with a 3.0L v6 3vze and an r150f transmission. Shifting into first seemed to be getting a little more difficult than usual for for a few days but got better when she was warmed up. There was no grinding either. I was pulling a trailer as well, which I didn’t normally do, so I thought the extra weight and old gear oil may have been the culprit. I wasn’t too concerned. Then all of the sudden I lost 1st and 2nd gear entirely. There was never any noise, and I could still shift into those positions, though the shifter had a lot of slack and would move way to far forward and past the 1st gear position. Also, I would still have power in those gears but it felt like I was still in third gear. I had no problems with 3rd, 4th, 5th, or reverse after that, but when I got into town I had to put it in 4 low to have enough power to start out. I figured it was the shifter bushing, so I replaced the two plastic bushing on the shifter (which were toast) with Marlin Crawler components. This fixed all the slack in my shifting and made my positions correct, however I still didn’t have first or second gear, and it still felt like I was in third gear in those positions. Begrudgingly, I pulled the transmission, but didn’t notice any extra metal floating around. Once out, I couldn’t get it to shift at all. Then I cleaned it up good and it shifted fine. However, I couldn’t find anything wrong with it, except for one tooth missing from the 1st gear synchronizer ring. I took it to a transmission shop and they couldn’t seem to find anything wrong with it either. All of the tolerances that I can measure without a complete teardown seem to be in spec, and all the gears look good, and bearings seem very acceptable. I have to wonder if that one brass tooth had been jammed somewhere and if the cleaning dislodged it. Without a bunch of extra money to throw at a phantom problem I am considering replacing the clutch and throwing it back in- though I am also hesitant to do all that work and find I am back at square one. Any advice will be appreciated.
