im wondering where to put an aftermarket temp sensor on my 22re. by the looks of it the factory one is at the upper coolant out let, but in the FSM it shows a "water thermo sensor" under the throttle body. im assuming if i unplug that sensor i might have cold start problems, but if put in the upper coolant tube then if the t-stat is closed its not gonna be an accurate reading. help
