Hi All! A question for the real gearheads. Approaching 200K miles on my '91 Toy 4x4 22RE, 5spd. With the rear axle off the ground and wheel removed, the hub rim will rotate rougly 1/8th" either direction before I feel resistance from the diff. It will rotate another 1/8th" before engaging the diff and moving the driveshaft to the t-case. U-Joints are tight and driveshaft seems tight. Makes me wonder how much rotational gear slop is too much? The Marlin diff is 1 yr new but all else is @ 200K near as I can tell.
