Author Topic: upper and lower control arm bushings  (Read 1265 times)
850scott
  • Member since Feb '13
« on: Feb 04, 2013, 10:46:51 AM »
I have an 86 4runner with a 6 inch trailmaster lift. The upper and lower control arm bushings are completely worn out. Trailmaster isn't making parts right now and can't give me dimensions. I can't measure parts that are falling apart. I do not have the money to do an sas right now. Does anyone have any helpful info? Thanks.
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
Re: upper and lower control arm bushings
« Reply #1 on: Feb 05, 2013, 01:06:55 AM »
The lift kit should have reused the oem control arms, I know my Trailmaster 4" kit did.  You can get new bushings here at Summit Racing for under $40.  It is a bit of a PITA to swap them out, expect to spend a good 6-8 hours per side when you do it.  You have to drill or torch out the old bushings, remove the fused rubber from the metal components, and press the new bushings in.  You can press them in at home using a large C-clamp if you freeze the assemble bushings overnight.  You will also want to have two new torsion bar bolts and nuts on hand, the old ones tend to break when trying to remove them.  If you have to use the truck for work, you can split the job up over two weekends, doing the lowers one weekend, and the uppers the following.
Given the age of your Runner, you will also want to replace the Body Mounts.
Last post Jul 17, 2006, 02:51:57 PM
by insane04
Last post Jun 26, 2007, 12:31:37 PM
by PoorCollegeCrawler
Last post Jul 28, 2008, 07:15:41 PM
by acerbis
Last post Jan 02, 2012, 02:59:05 AM
by Rocksurfer
Last post Jan 30, 2020, 05:26:43 AM
by OVRAROK
