Author Topic: RUF Caster  (Read 7488 times)
birfection
  • Turtle Points: -4
  • Male Posts: 203
  • Member since Oct '09
  • Drummond Island
RUF Caster
« on: Feb 24, 2011, 02:25:17 PM »
Just did rears up front on my rig with some 5 inch(eye to eye) boomerang shackles. My caster angle appears to be quite severe, even with the axle shimmed. I've heard shimming the front axle is a no-no to begin with, so what should i do to adjust this caster? Cut off the axle perches and rotate? Weld a steel shim to the perch? What have you guys done? Thanks for any help
TITAN CRUSHER      http://www.youtube.com/watch?v=v6qnDVgWBSA
1980 Pickup: 22RE (bored 20 over, OS Valves, 261 cam, ported and polished intake/exhaust, Pacesetter long-tube header), L52 5 Speed, 6 leaf RUF, 63" Chevies, Hi-steer, 35 x 12.5 Maxxis Creepy Crawlers, Dual 2.28 cases, Detroit Front, Welded Rear, 5.29s
GONZO97
  • Turtle Points: 48
  • Male Posts: 612
  • Member since Apr '09
  • travel the path less taken
    • Christian's Mattress Xpress
Re: RUF Caster
« Reply #1 on: Feb 24, 2011, 02:30:33 PM »
most people cut and rotate
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
Re: RUF Caster
« Reply #2 on: Feb 24, 2011, 02:57:22 PM »
build a drop box for the front to drop the front of your springs down.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
2manytoys
  • Turtle Points: 490
  • Male Posts: 583
  • Member since Nov '09
Re: RUF Caster
« Reply #3 on: Feb 24, 2011, 03:34:32 PM »
I'm planning a SAS with RUF on my 88 and I'm worried about caster issues.
Please keep us posted on how you fix it. With pics would be great.
Hope ya get it figured out.
superyota
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
Re: RUF Caster
« Reply #4 on: Feb 24, 2011, 03:39:53 PM »
read up on jrock's post.  he did this not too long ago.  i'm running ruf's on mine also and have basically the same thing done, just mine is a bit taller and moved forward further....
http://board.marlincrawler.com/index.php?topic=57178.msg912785#msg912785
ABD Motorsports
#4475
KK6QDW
birfection [OP]
  • Turtle Points: -4
  • Male Posts: 203
  • Drummond Island
Re: RUF Caster
« Reply #5 on: Feb 24, 2011, 06:59:56 PM »
Just to clarify-- when you guys say "cut and rotate", you're talking about the axle perches, right?   (I'm trying to avoid doing the drop hanger at this point)
Burl
  • Turtle Points: 271
  • Male Posts: 389
  • Member since Jan '07
  • Wannabe Smokejumper
Re: RUF Caster
« Reply #6 on: Feb 24, 2011, 07:07:42 PM »
yes and no the weld that holds the knuckle balls is what gets cut and turned then reweld that then reweld new spring perches on to the axle housing to accommodate the turned knuckle balls.
birfection [OP]
  • Turtle Points: -4
  • Male Posts: 203
  • Drummond Island
Re: RUF Caster
« Reply #7 on: Feb 24, 2011, 09:07:59 PM »
I'm not understanding why you have to cut and rotate BOTH the perch AND knuckle ball. Why not just one or the other?
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
  • Member since Sep '09
    • Poly Goats
Re: RUF Caster
« Reply #8 on: Feb 24, 2011, 10:02:30 PM »
You have to rotate the knuckles in order to accommodate the rotated perches. Think about it, if you just rotated the perches what would the knuckles look like? They would be at an off angle.
birfection [OP]
  • Turtle Points: -4
  • Male Posts: 203
  • Drummond Island
Re: RUF Caster
« Reply #9 on: Feb 25, 2011, 05:38:53 AM »
The whole reason I've thought to rotate the perches is to fix my caster angle(I want my knuckle to look like it's just about sitting level). If i cut off the perch and reposition it so that my caster angle is correct, I'm not seeing why repositioning the knuckle location would be necessary. I'm using the perch rotation to fix the knuckle angle.
yjay
  • Male Posts: 555
  • Member since Feb '09
  • SFA Station Wagon
Re: RUF Caster
« Reply #10 on: Feb 25, 2011, 06:21:04 AM »
http://www.4x4wire.com/toyota/tech/rotated_housing/
You want 3+ degrees of caster at the knuckles (preferably 5 to 7) if it will be driven on the street. In other words, if you were looking at the driver's side of your truck, the top trunion bearing should be more towards the rear of the vehicle, the bottom towards the front. You can avoid cutting the perches off if you turn your knuckle balls back say 7 degrees, weld on steel shims to adjust your pinion 4 degrees up, and bam, you add 3 degrees of caster and fix pinion angle. If you just use shims to rotate your pinion up you will lose the small amount of factory caster you have now and it will drive awful, wear tires, and death wobble.
Most death wobble issues are a result of insufficient caster.
« Last Edit: Feb 25, 2011, 06:29:54 AM by yjay »
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
-Jake-
  • Turtle Points: 9
  • Male Posts: 538
Re: RUF Caster
« Reply #11 on: Feb 25, 2011, 08:19:42 AM »
I've got a 5 spring RUF pack with the stock front hanger with 5.5" boomerang shackles and I can drive up to 60-70 mph on 40s without death wobble.  So if you haven't drove it yet you might wait to do anything.  I think I have around an 1/8" of toe in.
birfection [OP]
  • Turtle Points: -4
  • Male Posts: 203
  • Drummond Island
Re: RUF Caster
« Reply #12 on: Feb 25, 2011, 12:53:42 PM »
Jake, so you didn't use any shims on your perches? And you didn't modify your perches or knuckle balls in any way?
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: RUF Caster
« Reply #13 on: Feb 25, 2011, 03:10:37 PM »
With the cut and rotate, you are correcting two things caster and pinion angle, if you just cut the perches and relocate them for better caster your pinion angle will suffer.
yotarunner85
  • Turtle Points: 6
  • Male Posts: 166
  • San Diego, CA
Re: RUF Caster
« Reply #14 on: Feb 25, 2011, 04:21:31 PM »
X2
1985 Toyota 4Runner, BFG 35" MTs, 4" lift, Detroits lockers front & rear,5.29, V6 rear, rebuilt 22RE.
-Jake-
  • Turtle Points: 9
  • Male Posts: 538
Re: RUF Caster
« Reply #15 on: Feb 25, 2011, 05:01:37 PM »
yep.  maybe i'm just lucky who knows, but it rides and drives good.
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,048
  • Member since Aug '07
  • Heyo
Re: RUF Caster
« Reply #16 on: Feb 25, 2011, 05:21:54 PM »
I added axle shims to fix my pinion angle but then at full driver my drag link would rub my leaf. Cut and rotate at the knuckle is ideal, it keeps the pinion angle and fixes your caster.
Now I just have one 4 degree shim welded to the perch.
You'll never take me alive
birfection [OP]
  • Turtle Points: -4
  • Male Posts: 203
  • Drummond Island
Re: RUF Caster
« Reply #17 on: Feb 25, 2011, 05:47:31 PM »
Ok, so just to clarify the things you guys have said----If i relocate the perches and fix my caster angle, i just need to make sure the pinion angle is ok as well. If i relocate the perches for good caster and it just so happens that my pinion angle is alright too, that's all good, RIGHT?
OOPS
  • Male Posts: 2,561
Re: RUF Caster
« Reply #18 on: Feb 25, 2011, 07:11:08 PM »
That is right, but I will tell you right now it is going to mess with your pinion angle.
Slolyfe
  • Male Posts: 2,048
  • Heyo
Re: RUF Caster
« Reply #19 on: Feb 25, 2011, 09:07:10 PM »
Small shim, HP front 3rd, and dual cases. you should be fine
birfection [OP]
  • Turtle Points: -4
  • Male Posts: 203
  • Drummond Island
Re: RUF Caster
« Reply #20 on: Oct 26, 2011, 01:13:36 PM »
I've got the dual cases, now it's time to built a drop hanger! HP not in budget till next year
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • Member since May '07
  • I'LL NEVER MAKE IT...
Re: RUF Caster
« Reply #21 on: Oct 27, 2011, 05:18:05 PM »
Drop hanger and the weld on shims worked great on mine.  I even used the longer 3rd gen rears.
I'm also running rears up front on stock hanger and perches on an '80 with about a 5.5" shackle with the caster basically identical to stock but I'm running very few leaves so they are flattened out pretty good, like almost no net lift at all.
– Steve McQueen
Last post Jun 08, 2002, 08:29:33 AM
by BigMike
Last post Aug 19, 2004, 07:39:15 PM
by WHITE_TRASH
Last post Aug 25, 2005, 07:53:34 AM
by FIREBALL
Last post Mar 02, 2011, 06:16:48 AM
by GreenYoterKrawler
Last post May 23, 2011, 10:39:16 PM
by RockCrawlerAnonymous
