Author Topic: dual case oil question...  (Read 2393 times)
studentwheeler
  • Turtle Points: 121
  • Male Posts: 382
  • Member since Feb '06
« on: Apr 18, 2010, 12:45:06 AM »
Hey guys, just my duals in. Filled the crawl box with 1qt and the rear tcase with 2qts. Decided to check the fill plug to make sure that was enough oil. When I removed the plug oil poured out, I would say close to 1qt!!!
My question: Since the cases/tranny slope downwards towards the rear, did the oil from the crawl box move to the rear tcase?
Just trying to figure out why that much oil would have come out...and how to accurately fill 'em up.
Thanks!
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: dual case oil question...
« Reply #1 on: Apr 18, 2010, 09:19:05 AM »
did you completely disassemble the rear tcase or did you assume the rear case was empty??
chances are if you didnt disassemble the rear case a good bit of oil was still in it
studentwheeler [OP]
  • Male Posts: 382
« Reply #2 on: Apr 18, 2010, 11:46:20 AM »
Did not disassemble the cases, you are probably right and there was oil in it. To get the level right, would i just let the oil out until it is just barely coming out of the fill hole? Or, will there always be more oil than normal coming out due to the extra quart in the crawl box?
SFD4x4
  • Turtle Points: 4
  • Male Posts: 218
  • Member since Mar '10
« Reply #3 on: Apr 20, 2010, 05:44:37 PM »
I fill my dual cases by removing the front shifter and rear fill plug.  I put the oil in it until it just starts coming out of the fill hole.  Then I drive fairly slowly for about a minute to get the oil in all the gears.  Repeat filling from the the front shifter until it comes out of the filler again and your done.  If I was you I would drain your cases and refill them as above.
83 pickup, 4.88s, chevys in rear, RUF, Dual Transfers, flat belly, 3RZ swap, disc brake x4, rollin on 36" irocs
IF YOU SEE A 20' PAC WEST/CARSON FLAT BED TRAILER FOR SALE CHECK OUT THE STOLEN SECTION.  IT MIGHT BE MINE!!!!
SFD4x4
  • Turtle Points: 4
  • Male Posts: 218
« Reply #4 on: Apr 20, 2010, 05:46:06 PM »
The front one does drain into the rear one.
studentwheeler [OP]
  • Male Posts: 382
« Reply #5 on: Apr 20, 2010, 09:10:17 PM »
Will do that! Thanks!  :biggthumpup:
Last post Jan 23, 2007, 01:25:14 PM
by Boheefus
Last post Aug 26, 2009, 12:14:22 AM
by havik
Last post Jan 24, 2011, 07:50:09 AM
by GNasty 82
Last post Feb 12, 2013, 10:04:48 PM
by dingleberry87
Last post Feb 22, 2015, 04:20:42 PM
by Phazertwo
