Reply #1 on: Nov 26, 2009, 07:12:16 AM »
It is the auxiliary air valve that is located under the 1-2 plenum. The small hoses are water lines from the back side of the timing cover and the bottom of the throttle body, and the much larger hoes from the side of the top manifold to the bottom of the throttle body.
Marlin
Logged
