Author Topic: Tranny leaking oil  (Read 1655 times)
johnyreb69
  • Turtle Points: 77
  • Male Posts: 96
  • Member since Apr '04
Tranny leaking oil
« on: Nov 10, 2004, 02:44:29 PM »
I noticed fresh oil on the lower portion of my bell housing today so i checked the tranny oil lvl, found out it was low. I dont know where the oil came from but it is comming from the front of the bellhousing where the tranny mates with the rear of the engine. I dont think its the back of the oil pan, is it possible for tranny oil to leak out of the front of the tranny, if so how can i fix it? BTW its an 86 toyota 4runner 4WD 4cyc standard tranny
-- Fear is our only enemy
    Stand tall in the face of your enemies
    And you will conquer --
Bernabe Frank Rodriguez, EIT (Thats Me!)
Mike D
  • Turtle Points: 122
  • Male Posts: 1,902
  • Member since Jun '04
  • MMMMMMMMMM........
Re: Tranny leaking oil
« Reply #1 on: Nov 10, 2004, 04:35:27 PM »
Smell it and then you will know if it is tranny or engine oil.
johnyreb69 [OP]
  • Turtle Points: 77
  • Male Posts: 96
« Reply #2 on: Nov 11, 2004, 05:47:16 AM »
Engine oil has a gasoline smell, while tranny oil just stinks, correct? It doesnt smell like engine oil
supratruck
  • Turtle Points: 416
  • Member since Dec '02
  • I love Marlin Crawler!
« Reply #3 on: Nov 11, 2004, 06:42:52 AM »
Sounds like the  input seal is blown. This is rather common on older trannies. It can be replaced without tearing down the trans. The only hard part is pulling out the transmission. Once the tranny is out, cleanout the bellhousing with brake cleaner or something so nothing will get into the tranny when you pull the input cover( the part the clutch release bearing slides on). Pull the seal out of the back of the input cover and install the new one, be sure the back of the seal is facing the side that goes back on the tranny. Then polish the input shaft where the seal sits with a scotch brite pad, if the groove form the old seal is to deep(if you can catch your fingernail on it), hit it with some 400 grit sand paper to smooth it out. Check the clutch while the tranny is out. A good rule of thumb is if its more that 60% worn to replace it unless you like pulling out the tranny. You might need to replace it any way if it got soaked in gear oil. Be sure to replace the pilot and release bearing.
johnyreb69 [OP]
  • Turtle Points: 77
  • Male Posts: 96
« Reply #4 on: Nov 11, 2004, 05:03:07 PM »
i just bought the pilot,release bearing and the clutch to... did a tranny swap about 6 months ago... this sucks
Last post May 03, 2005, 10:30:48 AM
by Huhwhye
Last post Jul 26, 2005, 05:43:05 AM
by mr4x42u
im leaking.
Last post Apr 27, 2006, 10:35:10 AM
by Wermz84
Last post Nov 16, 2006, 02:36:39 PM
by *FFC*
Last post Jul 13, 2011, 04:53:25 PM
by Dirt Mover
