Author Topic: Location of Coolant Drain Plug on '91 2.4 Liter Engine (22-RE)  (Read 2050 times)
JD
  • Turtle Points: -1
  • Member since Sep '07
Can anyone give me an idea where this plug is located? I saw a rusty 17mm bolt on the driver's side of the engine about halfway up and halfway forward, and fought with it to no avail. I would like to make sure this is actually the drain plug before I break anything.
My coolant has not been flushed for about 8 years and I just replaced the radiator, so I figure this is a good time.
i bought some of the red Toyota coolant. It was hellishly expensive. Do you guys just use regular Prestone? I heard the Toyota stuff was better. Am using distilled water since the tap water here is full of minerals. That much I do know, not to use tap water in the cooling system.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
the drain is on the drivers side of the block about half way of the block height  but is closer to the rear of the block,  it SHOULD have a 14mm plug inside 17mm outer drain thingy
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
prestone is fine
the toyota red is supposed to last longer though... and it is hellishly expensive $25 a gallon if i remember right.... for that, i can just change the prestone 3 times, lol
JD [OP]
  • Turtle Points: -1
Thanks!
So I use a 14mm socket to loosen the plug or a 17mm?
  • Male Posts: 8,707
Thanks!
whichever fits, lol
if it isn't one, its the other
Black Runner
  • Turtle Points: -10
  • Male Posts: 198
  • Member since Dec '06
I had to remove the 17mm fitting cause it was plugged up. If you loosen the 14mm fitting and nothing comes out, then the larger one is probably plugged.
JD [OP]
  • Turtle Points: -1
All I found was a rusty 17mm bolt with no inner or outer part, just a 17mm bolt. I fought with it with the longest socket wrench I could find, but it rounded off without loosening. So I wound up just filling up and draining the radiator repeatedly with distilled water, with the heater on high, until it ran clear.
Not what I had hoped, but I guess it got the job done.
Last post Jul 06, 2004, 02:23:29 PM
by superstarai
Last post Oct 30, 2007, 10:22:16 AM
by dothemonkey
Last post Sep 25, 2015, 07:21:32 PM
by dt
Last post Aug 08, 2020, 02:00:46 AM
by Gnarly4X
Last post Jun 10, 2022, 11:14:56 AM
by slowpos
