I have an 86 sas 4runner and I have a pinion angle issue. My funds are lacking and I want my front driveline issue resolved. I was talking to a co-worker of mine and he said you may be able to remove the front 3rd member and flip it 180 degrees to fix pinion angle problems. Has anyone ever heard of this? Is it possible? I know the gear oil wouldn't sling as well but, has anyone tried it before? please give info.
what he is referring to is a hi pinion, that is all it IS NOT a flipped 3rd
Look closer at the front cover... drain plug on left, ring gear dentation on right. That is Reversed. A high pinion would have the ring gear on the same side. This is a clocked front 3rd
Started by toyhatsu Project Research and Build-Ups
Started by coconut General 4WD Discussion
Started by WhiteRhino Toyota Pickup/4Runner Tech 1979-95
Started by Yogatoy Engine
Started by trucker33 Newbie Questions
