Author Topic: does the body mount bracket need to be modified  (Read 1846 times)
AaronB
  • Turtle Points: 287
  • Male Posts: 2,452
  • Member since Nov '05
  • Wish I Was Crawling
« on: Dec 27, 2006, 02:46:56 PM »
So im doing a 5" trail flex lift on my 83'. Last night I test fitted one side. It looks like the bracket that comes out for the body mount needs to be notched out to let the hanger move adequetly.
« Last Edit: Dec 27, 2006, 02:57:16 PM by Aaronb »
AaronB [OP]
  • Male Posts: 2,452
Re: does the body mount bracket need tobe modified
« Reply #1 on: Dec 27, 2006, 02:56:33 PM »
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
no, it should be fine.  it doesn't move forward that far when the axle drops.
AaronB [OP]
  • Male Posts: 2,452
thanks
Shamb
  • Raisin in the making..
  • Turtle Points: 133
  • Male Posts: 3,414
  • Member since Oct '04
  • Proud Parent
one piece of advice, if you plan on running a large tire now is the perfect time to relocate the body mounts so your tire doesn't rub/catch on it.
When I had springs I used the closest hole to the frame and chopped the rest off because my tire would stuff up against that mount and eventually break birfs or chunk the tires really bad.
AaronB [OP]
  • Male Posts: 2,452
cool thanks, Ill have to see what I can do. But more than likely I wont go bigger than a 35"
Last post Sep 06, 2004, 06:42:11 PM
by ezthere
Last post Apr 02, 2006, 04:21:20 PM
by RustyToy
Last post Sep 28, 2011, 10:55:57 PM
by 84_yota_4wd
Last post May 09, 2012, 02:18:19 PM
by zr2runner
Last post Jul 10, 2017, 01:46:38 PM
by lamkinranch
