Author Topic: U-joint or rag joint for steering  (Read 3519 times)
dbbowen
  • Turtle Points: 265
  • Male Posts: 192
  • Member since Dec '15
  • Crawlin / St. Jude Childrens Research Hospital
« on: Feb 27, 2017, 10:05:47 AM »
Is it worth converting from a rag joint to a U joint for my steering shaft after I relocated my steering box?
OVRAROK
  • Online Silver Turtle Award
  • Turtle Points: 26739
  • Male Posts: 3,522
  • Member since Dec '10
Re: U-joint or rag joint for steering
« Reply #1 on: Feb 27, 2017, 11:13:47 AM »
I've been trying to find the rubber for my rag joint. Also what are you doing in regards to the steering shaft
Ritchie
  • Turtle Points: 539
  • Male Posts: 267
  • Member since May '13
  • Ritchie
« Reply #2 on: Feb 27, 2017, 03:49:41 PM »
Go with Sweet MFG joints, that's what I did.
Solid pieces for sure.
'03 Step side Pre-runner, F/R 4WU 3 linked, F/R Diamond axles, F/R ARB's w/5.29's, F/R Fox 12" CO's, ShrockWorks front bumper, self made rear bumper, WARN M8000S w/ remote, 4.7 Inchworm Lefty, MC sliders that hold air & a bunch of other stuff.
dbbowen [OP]
  • Male Posts: 192
« Reply #3 on: Mar 23, 2017, 06:52:52 AM »
Totally forgot about this post. I just melted the plastic out of it and bolted it up. I will eventually weld a spacer in to a new shaft if I can find one with a U joint locally lol
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #4 on: Apr 06, 2017, 02:44:10 PM »
The main reason for a "rag joint" is the body moves different then the frame.
OVRAROK
  • Male Posts: 3,522
« Reply #5 on: Apr 06, 2017, 02:59:37 PM »
do you know where to find rag joint dave?
OOPS
  • Male Posts: 2,561
« Reply #6 on: Apr 06, 2017, 03:12:41 PM »
There were a couple on runners at the P-N-P on Antelope that still had the steering boxes in them. You could use a holesaw and cut one out of the sidewall of a tire. My buddy did it and it worked fine for him!!
OVRAROK
  • Male Posts: 3,522
« Reply #7 on: Apr 06, 2017, 03:20:33 PM »
Thanks, ill go check p-n-p, and drilling holes in rubber is a pain. Would be a good trail fix though
OOPS
  • Male Posts: 2,561
« Reply #8 on: Apr 06, 2017, 03:50:02 PM »
He used this type of punch!!
OVRAROK
  • Male Posts: 3,522
« Reply #9 on: Apr 06, 2017, 04:22:17 PM »
Looks like an old leather punch
OOPS
  • Male Posts: 2,561
« Reply #10 on: Apr 06, 2017, 05:02:58 PM »
Really a set off punches used for gasket making, they went from 1/8th to 1". Those and a ballpeen hammer and you are set to make paper gaskets and punch holes in cork gasket material! Headgaskets were solid copper and if they were not scared up, you heated them to cherry red and reused them.
My buddy that restores antique MC's still does, pretty hard to find gaskets for a 1912 Indian!! LOL
Last post Jan 03, 2021, 12:29:08 PM
by OVRAROK
Last post Sep 09, 2011, 10:30:43 AM
by SloCrawler
Last post Aug 15, 2013, 03:56:30 PM
by emsvitil
Last post Mar 01, 2017, 01:59:32 PM
by OVRAROK
Last post Sep 18, 2020, 03:56:57 PM
by Eschenfeldt
