Author Topic: "Normal" 22RE Timing chain noise  (Read 24000 times)
Jagdverband44
  • Turtle Points: -1
  • Male Posts: 155
  • Member since Mar '07
Re: "Normal" 22RE Timing chain noise
« on: May 05, 2011, 12:02:04 AM »
what oil filter are you running? If the oil pump "O" ring is not installed correctly it may leak pressure out of that.
 OEM Toy filter. I found the knock at idle could be ignition related, but I doubt it because the pressure needle is at the bottom range of acceptable when the engine is hot. Once I get a new ECU, the timing chain and oil pump are getting replaced. Also, I'm running a 15w40 and may go to a 10w30 next time.
I've got the most liftedest truck in town, that little jap truck done stand no chance gainst my Chevy. My Chevy gots a V8 more lift an bigger tires,and an exhaust system, whats yer tuna can got, a V4, and them tires look like they is offa Saturn Corulla. The dealer instulled my lift, so ya no its done right, you just try to foller me throo them rocks an see what a reel truck can do.
Last post Jul 09, 2006, 04:11:28 PM
by jimbo74
Last post Aug 30, 2006, 07:49:08 PM
by reklund5
Last post Mar 11, 2007, 06:35:33 PM
by wrenchtech
Last post Jul 09, 2009, 12:04:56 PM
by basser530
Last post Oct 23, 2009, 09:27:51 PM
by crawlerdad
