Author Topic: another vibration question  (Read 2589 times)
Burl Earl
  • Male Posts: 39
  • Member since Apr '08
  • Tearing it up in 2wd
Re: another vibration question
« on: Aug 17, 2008, 01:54:11 PM »
What are the odds of it being my 4th gear in my trans?  I was in 4th at around the same speed when it locked up.  I also don't have the problem when i'm going through that speed in third gear.  Any thoughts?  Also wouldn't I notice it in my clutch if the fly wheel was warped?
if it is 4th gear your going to need a new main shaft in your transmission because 4th gear is 1:1. which means your crank speed is the same as your transmission, output & driveline speed. also, replacing your main in the transmission means replacing all the helical gears in th transmission. it would be a lot easier to get a new trans or upgrade to the 23 spline turbo trans. :yesnod: as for the flywheel/clutch warpage. if you have a dial indicator you can use that to check the out of round and warpage. otherwise use a straight edge and feeler gauges. put feeler gauge on a part of the flywheel put straight edge on top. then try to pull out the feeler gauge. if it moves the straight edge then it is smaller than that feeler gauge. check about 6 places around the flywheel.
Quote from: 1985efiyota
next thing you know marlin will be makin a moon crawler for nasa
gotta be Burl to be called Earl
83 Toyota P/U Webber carb. Sky high-steer, front drop hanger & rear  hock hoop. Marlin brake lines, IFS mount, rear spring mount & shackles. Trail-Gear front 12" shock hoop. Rancho RS900X 12" Adj shocks. All-Pro 6" front springs & Triple XXX cross member w/ e-brake. 63" chevy springs rear w/ 3" blocks. Removable mud flaps.
Thread, Build and Pics Click Here
Last post Nov 20, 2004, 08:25:01 PM
by SWAMPER
Last post May 15, 2005, 03:06:53 PM
by synwars
Last post Jul 02, 2005, 11:14:42 AM
by BoMXtreme
Vibration question
Last post Jan 15, 2009, 04:55:14 PM
by 82 HiLux
Last post May 20, 2016, 07:04:06 PM
by emsvitil
