Author Topic: 1989 4runner automatic tranny  (Read 1776 times)
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re: 1989 4runner automatic tranny
« on: Sep 29, 2004, 09:02:26 PM »
It is possible to remove the auto without draining the oil.
A little oil will leak from the cooler lines but the oil in the pan will stay there unless it flows out the dip stick tube.
Marlin
Last post Apr 08, 2004, 11:13:48 AM
by pickeledpigsfeet
Last post Sep 01, 2004, 11:03:38 PM
by ezthere
Last post Jan 13, 2009, 07:56:36 PM
by Snowtoy
Last post Apr 15, 2010, 08:45:35 AM
by COToy91
Last post Apr 13, 2016, 02:41:45 PM
by Mudder
