Author Topic: 3vze water pump HELP!!!!!  (Read 5710 times)
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
Re: 3vze water pump HELP!!!!!
« on: Oct 15, 2007, 10:34:35 PM »
sorry, I got the radiator pulled and all that, and took off that black cover that hides the timing belt and dont know what to do after that, what do you take off to get the the pump
You need to pop the tensioner spring of the timing belt tensioner, and then remove the timing belt. Before you do that, set your timing @ TDC.  your crank pulley mark will line up with 0* on the marking thing (about 2 o clock on the crank pulley) and then cam marks should both line up with the marks on the rear timing cover (straight up)  if that isn't the case, spin the motor by hand using a ratchet on the crank pulley until they all line up. You'll also need to remove the PS pump belt, and the alternator belt.
After the timing belt is off, you'll have to remove the fan clutch and bracket assembly.  By this time you should see right where the water pump is (t-stat housing that the radiator hose goes to is part of it) Remove the other stuff that is in the way (don't remember exactly what else there is) and pull it out and replace it.  While you're in there, I would strongly recommend replacing that timing belt.  To do that, you'll have to pull off the crank pulley, and take off the lower timing belt cover.  if you screw up the alignment of the timing marks pulling the crank bolt off (its difficult to get off), don't worry, just make sure the mark on the crank, and the marks on the cams are all lined up before you put it all back together.  :thumbs:
Hopefully that wasn't too confusing.  Make sure you clearly mark where your bolts came from, and how they are to go back in :thumbs:  I believe the waterpump itself has 2 different sized bolts, and you have to put the right length bolts in the right places.
Feel free to PM me if you need more help, and if you can take pics, those will allow me to help you better if you get stuck.  I'm telling you this from memory, so a pic will certainly be a refresher. :thumbs:
              -Ronald Reagan
Last post Jun 20, 2006, 09:32:30 AM
by Mike D
Last post Jun 21, 2006, 08:50:33 PM
by BUDDERS
Last post Dec 18, 2006, 12:58:31 AM
by mikerob
Last post Apr 13, 2008, 10:24:45 PM
by kneedownnate
Last post Nov 14, 2023, 09:16:17 AM
by RUGER
