Author Topic: Idle goes down when ac is engaged  (Read 1254 times)
  • Administrator
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: Idle goes down when ac is engaged
« on: Jan 08, 2006, 06:57:13 PM »
The AC Idle up valve could be routed wrong, or plugged. Does it make a difference if it is screwed all the way in or out?
Also, does your truck warm up correctly? Even if it reads 40% on the temp gauge, have you felt the upper radiator hose while it's warmed up? If it is really ~190 degrees, then you wouldn't be able to hold onto the hose for more then about 2-3 seconds.
I ask this because the A/C is supposed to not work the idle up when the truck is cold because it is still using the cold idle. It also incorporates 4WD with the system, but I have never seen a difference. I've used AC in Marlin's 4WD truck both with it cold and in 4WD and it worked just fine :headscratch:
Last post Mar 02, 2005, 10:11:00 PM
by AlaskaToy
Last post Jan 02, 2006, 06:32:03 PM
by Uncle Jesse
Last post May 03, 2005, 10:22:03 AM
by 91 super yoda
Last post Jan 19, 2010, 11:29:49 AM
by anfkndy
Last post Jan 11, 2010, 03:52:51 PM
by jonathan82toy
