Author Topic: Difference between efi and Carb fuel tank  (Read 3390 times)
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
Re: Difference between efi and Carb fuel tank
« on: Nov 10, 2012, 02:05:22 PM »
nothing like asking a question then pretty much calling "MOST OF US" idiots...... not a very good way to get an answer...
i have used an tank from an 85 4runner (efi) in a 84 4runner (carb) by just changing the fuel pump pickup module.... everything worked fine, but if you look at the numbers online they do list seperate fuel tanks for carb and EFI, not to mention there is a size alteration mid year 86...
im just assuming here, but it sounds like you may have a fuel injected tank with an carb engine, i would first try just disconnecting the fuel pump and see if the stock mechanical pump on the block will pull fuel through...
Those are some huge welds!
Tillamook, OR
Last post Feb 24, 2008, 06:21:29 PM
by pyrosnow911
Last post Apr 28, 2008, 10:08:27 PM
by jimbo74
Last post Apr 21, 2008, 12:40:58 AM
by dizzydevil
Last post May 17, 2009, 07:26:19 AM
by Redbeard3261
Last post Jul 11, 2012, 01:44:52 PM
by lone walker
