IFS hubs on a solid axle, no spacer, stock rotors and calipers
Started by zmwworm, February 22, 2008, 04:52:06 PM
zmwworm
I want to use some IFS hubs on my 82 pickup, but as cheaply as possible.  I would like to do it with the directions from an old post, which I'll repost here:
Quoteyou need to drill the IFS rotor fixing bolt pattern into the fj rotors I have a buddy at a metal shop help me lay out the pionts to drill on the rotor and then we drilled the holes. It is easy to drill the cast iron and you don't need to lube your bit because of the carbon in the metal
bolt the fj rotors to the ifs hubs and change the seals if you want I did since I was there.And grease the wheel bearings.
Now that the rotor and hub is ready remove all your solid axle  FPRIVATE "TYPE=PICT;ALT=Pokinit" from the knuckle except for the steering arms and birfields
take your dust shield drill and 5/16" bit and look for the pinch welds between the spindle holes and drill the untill the spacer comes free about 1/16" thick piece of steel is welded onto the dust shield with the spindle bolt pattern you need that thin spacer. there was only 2 welds per dust shield on mine throw out your dust shield and keep the thin spacers. Now put some black silicone on the knuckle and the spindle 1 per side like they came off, take the thin spacer line up the bolt patter and stick it to the knuckle then stick the spindle the knucle and bolt it in place.Now you are ready to mount the ifs hub and fj rotor.
Now take your 1/2" bit and drill out the threads on the knuckle for mounting the calipers make sure you drill the straight if you look you will see that you are drilling out a little more material than just the threads, poke your 1/2' bolts threw to make sure they fit.
Now get your 1/2" tap and start taping threads into the caliper.It is easy and doesn't take long take your time and make sure it is straight and the tap will guide it's self in the hole. The 1/2" tap is bigger than the 12mm hole and alows you to just cut threads. I lubed the tap with oil to make it easier. Also if the tap binds up back it out a half turn to clean it then start tapiping again. Now thread the 1/2" bolts in . Sweet they fit nice and tight now clean everything and get ready for reassembly.
mount the knew hubs and rotors tighten your wheel bearings mount your original locking hubs and know install brake pads. Mount the caliper on the other side of the ears on the knuckle tighten the 1/2' bolts and take for a test drive.
http://board.marlincrawler.com/index.php?topic=7449.30
The thing is, I would like to use my old rotors and calipers if at all possible.  Will they fit using the above method, or are the calipers too small or something?  Here are the dimensions of the different rotors:
QuoteThe stock solid axle rotors are 13mm thick and 302mm diameter, the later model vented L.C. are 20mm thick and 302mm diameter and both have a total height of 49mm. The IFS rotors are 20mm thick and 289mm diameter with a height of 64.5mm.
http://www.pirate4x4.com/forum/showthread.php?t=515697
The total height is the same between the FJ and the SA rotors, but the disc thickness is the same between the FJ and the IFS.  So I guess the real question is can you normally swap stock rotors and calipers for FJ and IFS ones without spacers or anything?  If you can in the normal location than you probably can with IFS hubs, right?
After writing this, I looked at the Sky Manufacturing site and they say that their spacers work with either stock parts or FJ and IFS rotors and calipers, so when put in the stock location the IFS calipers must have the same distance from the front of the mounting holes to the back of the rotor as the stock parts do.  But when you have calipers on the other side of the ears, then the distance between the back of the mounting holes to the rotor needs to also be the same.  So do SA and IFS calipers have the same thickness at the mounting holes?
boggerunner
zmwworm
That's probably better (read cheaper) than the Sky kit, but I'd have to buy rotors and calipers in addition to the hubs.  But for a cost of $50 I'd like to know where you got the spacers?
boggerunner
