Author Topic: Operation triage..  (Read 2421 times)
Bluewatervet
  • Turtle Points: -108
  • Male Posts: 63
  • Member since Oct '14
Operation triage..
« on: Oct 30, 2014, 02:02:45 PM »
So with the recent trading of truck I have in my possession a sas 93 pickup. Sounds good right? Well let's dive in...
1. Efi has been half cut out and replaced with a Holley 350 carb. (Wtf why!)
2. Shock hoops were hand made instead of the $60 one from trail gear or marlin crawler. (Another wtf)
Well you get the idea so far, as I put up pics ill comment about what I see that's wrong and needs fixing and feel free to chime in if there's something I miss or could do better.
First how I got her..
Bluewatervet [OP]
  • Male Posts: 63
Re: Operation triage..
« Reply #1 on: Oct 30, 2014, 02:05:50 PM »
Got rid of the ridiculous 20x12 rims with 38x15.5 tires for these in a trade... 35x12 km2s (basically new tires still have little feelers on them) on 15" rims.
Bluewatervet [OP]
  • Male Posts: 63
« Reply #2 on: Oct 30, 2014, 02:07:14 PM »
Here we have the handmade hoops that have so much travel ( note sarcasm )
toyodaaddict
  • Turtle Points: 399
  • Male Posts: 1,142
  • Member since Sep '08
« Reply #3 on: Oct 30, 2014, 02:30:43 PM »
that is a tall truck :yikes: looks like you have some work ahead of you.
Bluewatervet [OP]
  • Male Posts: 63
« Reply #4 on: Oct 30, 2014, 06:45:49 PM »
It's really tall due to the ridiculous body lift and block combo, which are on the extensive replacement/ditch list. Not a fan of block since I've spit two out on separate occasions and fixed on trail which sucks. Never messed with body lift always seemed pointless and don't really like to look of it. So blocks will be easy so long as nuts back off. Body lift?? Could take a few hours... But over all yes there is a lot of building in my future but I'm ok with that. It kinda takes me away from the world...
1985CRAWLER
  • Turtle Points: 267
  • Male Posts: 1,163
  • Member since Feb '13
  • Backyard Built
« Reply #5 on: Oct 30, 2014, 10:11:05 PM »
good lord, you mustve gotten a good deal on that mall crawler lol  EFI to carb? WTF?? :slap:
yea those shock hoops i think have less travel then stock 84/85 towers.bahah
bob it,lock it,and slam it, ditch the blocks,and lame body lift and get some armor on it and wheel it hard
Bluewatervet [OP]
  • Male Posts: 63
« Reply #6 on: Nov 02, 2014, 10:54:47 AM »
Well I just ordered new shock hoops and a stud eliminator kit for rear pinion. I will try to post some pics while doing the eliminator kit. Once rearend has the new seal and studs, I will take it to a friends shop and cut/grind off old hoops and weld on new ones.
Next item needing replacement is front and rear shocks, fronts are blown from bottoming out, really not even the right size for the amount of lift. Fully compressed it has a total of 20" length and full extension was 29".
« Last Edit: Nov 02, 2014, 11:08:34 AM by Bluewatervet »
84Flatbed
  • Turtle Points: -196
  • Member since Jun '13
« Reply #7 on: Nov 02, 2014, 11:52:10 AM »
You said it has blocks right? While your at it you should pull the blocks. I'm curious to know what springs you have in the rear, your shackle angle looks pretty straight. What length (hole to hole) are those rear shackles. Do you have any better pictures of the front and rear suspension?
Bluewatervet [OP]
  • Male Posts: 63
« Reply #8 on: Nov 02, 2014, 01:42:49 PM »
Will have to go out and measure. I'll put rear spring length on here too. I had planned on pulling blocks after fixing shock hoops, it's looking there will be a 1" height difference front to rear but that's not a big deal right now. Don't plan to take it off-road till I get the basics fixed and some trail armor.. So until then she's a street queen :-\
Bluewatervet [OP]
  • Male Posts: 63
« Reply #9 on: Nov 02, 2014, 03:27:50 PM »
The rear shackle is 7" from eye to eye.
 Rear spring is 52" overall, 23" from center of perch forward and 29 from center back.
Bluewatervet [OP]
  • Male Posts: 63
« Reply #10 on: Nov 05, 2014, 12:59:28 PM »
Here's how even the rear shocks are setup and you can also see how big the rear shackles are.
Last post Dec 11, 2006, 06:56:53 PM
by DTB
Last post Jul 01, 2006, 08:25:03 AM
by 79coyotefrg
Last post Mar 05, 2007, 09:21:17 PM
by rage
Last post Jul 12, 2010, 06:24:29 AM
by 87toyotaman
Last post Dec 04, 2011, 08:11:05 PM
by thebigdogg
