Author Topic: 86 Runner Clean Build, San Jose Ca (Sold)  (Read 10686 times)
86moneypit
  • Trade Count: (+1)
  • Turtle Points: -8
  • Male Posts: 807
  • Member since Jul '07
  • Go Big
« on: Jul 17, 2014, 09:13:31 AM »
I have a nice 86 runner built for DD and crawling. I'm not in a rush to seal just want something better for driving to trails and hauling the family.  I want something with more power and better axles and don't have the time to do the mods I want to on mine so I’m going to try and sell it and buy one all set up.
Location San Jose Ca
Martin 408-398-1884
SOLD
The Bad First
•   few dents but nothing to bad
•   tire career got hit and is hard to close (I removed it for now)
•   Cold start injector is out(Starts fine after its warmed up)
front axle could use a once over but its in good working order now
Suspension & Axles
Front
•   5” Marlin Springs ( took out bottom leaf to lower front and flex better )
•   Bilstein 5150 14” shocks
•   Marlin shock hoops
•   Marlin front axle shock and end brace kit welded in
•   Marlin front axle top truss
•   85 housing rebuild about 3 year ago with marlin rebuild kit
•   529 R&P with locker ( came with axle)
•   Marlin 27 spline outers stock inners
•   Trail gear cross over steering and arms
•   ARP arm studs for hydro
•   Rebuilt steering box taped for hydro
•   Steering stabilized ( planned to take off after hydro went on)
•   Upgrade front brakes to V6 along with master cylinder
Rear
•   86 housing (With custom top brace that I made)
•   TG Diff guard
•   New Yukon 529 gears with Detroit ( 3 year old)
•   6” Marlin HD springs ( work well with all the weight for the ass end)
•   Bilistein 14” 5125 set up on a /\
•   New brake hard lines on rear axle with marlin breather tube.
Engine and t-case
•   Motor from an 88 truck with 140k on bottom end and 10k on head is what the guy told me that I bought the engine and tranny from.
•   All new components on motor water pump PS pump and all belts hoses motor mounts.
•   LCE cal legal header to  a new cal legal cat with1 chamber flow ( sounds good for a 4 banger)
•   Enginbulder mid-range cam that I put in when I swapped in the new motor
•   Engine was stripped to block when I got it and freshened up with all new gaskets.
•   Stock w56 b tranny with marlin 1200LB clutch.
•   Dual stock cases with marlin adapter
•   Drive shaftes done by bay drive line in Pittsburg ca
•   Unknown cross member that bought for cheap and modified to fit my set up.
•   A/C works ok
•   Heater is hot as :pokinit: like all yotas
•   GM 3 wire CS-130 105Amp alternator swap done.  Upgrade all grounds to 2ga. And ran new 2ga. Wire for alternator to battery.
Body Armor,
•   Custom plate front bumper that I made with warn xd90001 and some lights ( kind of want to keep the winch) http://board.marlincrawler.com/index.php?topic=67374.msg815814#msg815814
•   2x4 sliders that I made
•   Marlin rear bumper with a swing out spare tire career that I added to the rear bumper
•   http://board.marlincrawler.com/index.php?topic=71003.0
•   Tried to plan for exo when I built the bumpers and sliders so you could add cage stuff later.
Other Stuff
•   LED Rock lights with switches in the dash (wired nice with relays)
•   I Made a new center counsel
•   Pull out drawers in the back for storage
•   New speakers and deck
•   Big stereo system in back, 2/8” subs and 1/10” sub with two amps( Would probably keep this)
•   20LB co2 tank holder for air ( id keep the tank)
•   High lift holder on top of the speaker box cross bar( no one will steel my :pokinit: with the top off)
•   Clean interior
•   Spare 37MTR
•   Sits on 37 BFG KM2s and fake beadd locks
•   Half doors with cup holders and nice wood panels in side
•   Rig was a sr5 when I got it but I took all the power window stuff out because it didn’t work.
•   Wired the back window with a different switch in the front conceal to bypass the stock crap that      doesn’t  work
•   Spare rear d-shaft mounted in the rear bumper
•   I made a bikini top out of a FJ40 Bikini top and made my own mounts and other stuff.
Integra front seats, very comfortable for long trips, bolted in the right way with factory seatbelts.
All I can think of for now.
« Last Edit: Jan 25, 2016, 06:00:53 AM by 86moneypit »
86 Runner 529s locked duals 37s
96 Runner 5sp. 3.4 32s DD
04.5 Dodge 2500 CTD With Go Fast Stuff On It
Drive it like you stole it
86moneypit [OP]
  • Trade Count: (+1)
  • Turtle Points: -8
  • Male Posts: 807
  • Go Big
Re: 86 Runner Clean Build, San Jose Ca
« Reply #1 on: Jul 17, 2014, 09:15:26 AM »
More
86moneypit [OP]
  • Trade Count: (+1)
  • Turtle Points: -8
  • Male Posts: 807
  • Go Big
« Reply #2 on: Jul 17, 2014, 09:18:42 AM »
More
twistedtoy92
  • Trade Count: (0)
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
« Reply #3 on: Jul 22, 2014, 09:33:13 PM »
Bump for a sweet runner. Goodluck with sale!
86moneypit [OP]
  • Trade Count: (+1)
  • Turtle Points: -8
  • Male Posts: 807
  • Go Big
« Reply #4 on: Jul 23, 2014, 11:53:32 AM »
Thanks man,
If know one wants to buy it ill probably give it an overhaul, bigger motor and ditch the yota axles so I can run 40's and drive it to the trails.
studentwheeler
  • Trade Count: (0)
  • Turtle Points: 121
  • Male Posts: 382
  • Member since Feb '06
« Reply #5 on: Aug 13, 2014, 10:02:10 PM »
Bump for a nice rig. Seen it in person, clean.
86moneypit [OP]
  • Trade Count: (+1)
  • Turtle Points: -8
  • Male Posts: 807
  • Go Big
« Reply #6 on: Aug 14, 2014, 09:43:52 AM »
Thanks Guy's.
86moneypit [OP]
  • Trade Count: (+1)
  • Turtle Points: -8
  • Male Posts: 807
  • Go Big
« Reply #7 on: Oct 07, 2014, 02:44:41 PM »
Update.
I sold the iroks and put some 37 KM2s on her to get it back to more of a drivable rig.
Pretty firm on the price now since the wheels and tires wert cheap but it drives so much nicer now.
thebrick
  • Trade Count: (0)
  • Male Posts: 8
  • Member since Aug '10
Still for sale?
86moneypit [OP]
  • Trade Count: (+1)
  • Turtle Points: -8
  • Male Posts: 807
  • Go Big
Yes it is.
86moneypit [OP]
  • Trade Count: (+1)
  • Turtle Points: -8
  • Male Posts: 807
  • Go Big
Here are some pics of the bikini top.
86moneypit [OP]
  • Trade Count: (+1)
  • Turtle Points: -8
  • Male Posts: 807
  • Go Big
Back for sale guys, I was hoping to start using it again after our new little guy but time is better spent with him now and I want to build stoning else in the future.
bigarms23
  • Trade Count: (0)
  • Turtle Points: 111
  • Male Posts: 2,897
  • Member since Jun '07
shoot i wish i knew this was for sale last week when i was visiting woodside i would have picked it up
86moneypit [OP]
  • Trade Count: (+1)
  • Turtle Points: -8
  • Male Posts: 807
  • Go Big
yea I just decided to put her back up after much thought, been my grocery getter for the past year and it needs a home that will put it to good use.
SqWADoosh
  • Trade Count: (+1)
  • Turtle Points: 10966
  • Male Posts: 2,417
  • Member since Oct '14
Great looking build. Best of luck.
86moneypit [OP]
  • Trade Count: (+1)
  • Turtle Points: -8
  • Male Posts: 807
  • Go Big
Sale Pending.
Last post Feb 22, 2006, 02:14:46 AM
by YeloSub7
Last post Jul 23, 2007, 02:58:40 PM
by 86moneypit
Last post Aug 23, 2009, 02:40:48 PM
by 83 Crawler
Last post Sep 10, 2014, 09:10:24 PM
by 86moneypit
Last post Nov 10, 2014, 10:52:34 AM
by 86moneypit
