like drill the knuckel where the bolt woult connect it to the caliper?
The diameter is the same as the 4 cyl and V6. I had it all written down and don't know what I did with it.The T100 thickness is about 1" and the V6 is approx. 7/8" I think the specs are listed in product details on Autozone's website.I used 1995 T100 without ABS to look them up. I'm pretty sure the rotor diameter and thickness is listed. I did not find info on piston sizes however. Hope this helps.
i found the specs, the T100 and SR5 4runner of the same 1995 year model share the same brake rotors and calipers.
Glen, I hope you figure out how to make this work on your straight axle. These work great on my IFS and I'd like to make them work on the 85 SA I'm putting together.
Started by jr9162 Toyota Pickup/4Runner Tech 1979-95
Started by toyofan7987 Toyota Pickup/4Runner Tech 1979-95
Started by 05xrolla Engine
Started by madmax886 Engine
Started by anarchy joe Toyota Pickup/4Runner Tech 1979-95
