Author Topic: 5.71's or stay with my 5.29's?  (Read 5904 times)
yoter4x4
  • Turtle Points: 31
  • Member since Dec '08
  • Team Bungie!
« on: Jul 06, 2010, 10:04:17 PM »
a local wheeler here where i live told me to hold up on welding my rear diff on my 83' yota with 5.29's and 35's because he will be selling the axles from underneath his 84 pickup both locked with 5.71 gears... both axles have welded spiders. i think i'd just install his rear axle, than pull my 5.29's and install his 5.71's in my toyota front.
now this is the kicker, i heard 5.71's are kind of a sketchy gear for trail gunning because the pinion is smaller and more likely to give out versus the 5.29 pinion..... is this true? any of you guys run 5.71's on the trail? i guess i just wanted to know how much weaker it really is
i guess if anything i could just swap back to my 5.29's if i blow the 5.71's out. All depends on how much he wants to sell this set of axles for!!
thanks for the input guys.
Bullets don't know the difference between race, sex, or gender.. They Just Feed On Flesh!
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
  • Member since Oct '06
Re: 5.71's or stay with my 5.29's?
« Reply #1 on: Jul 06, 2010, 10:27:42 PM »
this has been covered a ton.
some say 1 while others say the other.
I only run 488s oem I have never broke one.
I have broke after mkt 488s 529s 571s..
they will all work and they will all break.
Id say 529s but he@l what do I know.
yoter4x4 [OP]
  • Turtle Points: 31
  • Team Bungie!
« Reply #2 on: Jul 06, 2010, 11:22:24 PM »
yeah i sort of figured it was more of a preference over product type deal.
my truck is only a 3-4+ truck, i'm not the climbing waterfalls hangin from my wich strap while pumpin my brakes and running a hand throttle as all 4 tires are wedged into a tight crack type of wheeler quite yet so i think either set will do me just fine.
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
« Reply #3 on: Jul 06, 2010, 11:54:11 PM »
i have 5.29s never had a problem with em....
but
http://gearinstalls.com/410suck.htm
Those are some huge welds!
Tillamook, OR
yoter4x4 [OP]
  • Turtle Points: 31
  • Team Bungie!
« Reply #4 on: Jul 07, 2010, 02:35:17 AM »
wow that was a really helpful write up. thank you
mtm
  • Male Posts: 58
  • Member since Nov '09
« Reply #5 on: Jul 08, 2010, 04:32:56 PM »
iam running 5.29 with no problems
hilux 82 with mk3 2.4d engine. bobed 18 inches, full soft top, 9 inches of lift,exo cage,swing out tyre carrier, front tube winchbumper with x9, rock sliders, rear tube bumper, front truetrac and rear arb lockers, twin trans adapter with 4.7 crawler gears,20 forward and 4 reverse gears, 38 inch super swampers , rear disc brake conversion, trans disc parking brake, 5.29 r&p ,rear bench seat,hand throtle,custom storage boxes, custom made snorkel,onboard air compressor,cb twin bateries,split charge system, diff guards, low profile gearbox mo
happakidd
  • Member since Mar '06
« Reply #6 on: Jul 12, 2010, 12:14:57 PM »
I run 5.29s no probs, i hear welded spiders can cause issues also, a lot of people say spools hold up better to the abuse
Caboose
  • Turtle Points: 62
  • Male Posts: 733
  • Member since Jan '05
  • Truth... Justice... Honor...
« Reply #7 on: Jul 12, 2010, 12:22:08 PM »
is your truck a DD?  I have never been a fan of welded diffs on DDs.  My buddies have them and dont like driving their rigs on the street because they wear tires way faster.  Just save a little extra and get a aussie/lockright
"Who let the jeeps come?
Easy... easy..." -2 people on the CB
81 Toy Pickup SR5
http://board.marlincrawler.com/index.php?topic=35701.0
Daily Driver: 96 Dodge Ram 2nd DD/Tow Rig
yoter4x4 [OP]
  • Turtle Points: 31
  • Team Bungie!
« Reply #8 on: Jul 12, 2010, 03:23:49 PM »
rear is already welded. with 3 different projects to finish, i don't really wanna spend $300 on a locker for my beat up old toy when i have a beautiful 66 bronco that needs that money instead.
my buddys welded rear in his 83 toy works great. his sx's have pretty even wear
my toyota used to be a DD thats why i didnt weld the rear before, but for a while now i have had 2 other daily drivers so the toy is driven to show off in or wheel now only.
GloNDark
  • Turtle Points: -1
  • Male Posts: 282
  • Member since Nov '03
« Reply #9 on: Jul 16, 2010, 11:10:56 AM »
5.71's are junk. They are hard to install correctly, and get a decent gear pattern out of them. The pinion is tiny and from what I saw with mine you only have a maximum of 1 tooth contacting the ring gear at a time.
The gears in my truck were 6 months old when I bought the truck and the rear pinion was completely chewed. Bought a set of new gears for it, spent 2 days getting a good pattern out of them and still wasn't happy with it.
I know lots of sammi guys runing the 5.71s with ok luck, but i've not heard or seen anything good when they are under the heavier toyota trucks.
As far as welded spiders, i've run welded spiders in the rear of nearly all of the rigs that i've had. I like it because it's very consistant, no "unlocking" all of the sudden on the highway, i've seen no weird tire wear from them, matter of fact my only complaints is the tires barking a little bit when I'm pulling into a really tight parking spot on asphault. Other than that, It's cheap and easy traction that works great.
yoter4x4 [OP]
  • Turtle Points: 31
  • Team Bungie!
« Reply #10 on: Jul 18, 2010, 04:45:31 PM »
all i can say is "word" i'm stayin with the 5.29's thanks for the info guys
dirtchicken
  • Turtle Points: -44
  • Member since Nov '06
« Reply #11 on: Jul 20, 2010, 10:13:53 PM »
Zuk has a guy running 5.71s with a 4.3/th350 and toy duals with 4.7s in the rear case on 42"s. GloNDark says they are junk though.
yoter4x4 [OP]
  • Turtle Points: 31
  • Team Bungie!
« Reply #12 on: Jul 20, 2010, 11:45:50 PM »
before it gets to hostile, i think the desicion is more mind over matter like i stated previously. i know 5.29's are probably much more common, and with dual cases who could really tell the difference anyway, duals are my next upgrade more than likely
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
« Reply #13 on: Jul 20, 2010, 11:50:47 PM »
i ran 5.71s and 42's for almost 2 years, wheeled it with no problems.  finally blew them up after the back end started hopping and i stepped into in harder.  downsized to 37's for now with 5.29's.  i'm happy.  i wouldn't be afraid of running 5.71s again.  almost wish i had them now.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
  • Administrator
  • Turtle Points: 2124
  • Male Posts: 18,291
  • Member since Apr '02
  • 511:1 Club
« Reply #14 on: Jul 21, 2010, 12:32:27 AM »
I've been waiting for this article to be finished for a long time. He is barking up the hopeless tree.
ZUK
  • Turtle Points: 9
  • Male Posts: 168
  • Member since Nov '02
    • ZUK's Gear installs
« Reply #15 on: Jul 21, 2010, 03:49:24 PM »
Here's a local guy (Chris in Mesa, AZ) that had me install a PRECISION 571 back in '05....he started with 37" tires I think....went up to 39"...and less than 2 years ago he upgraded to 42".  I believe 571 gears are 'reserved' for the hardcore off-roaders....the guys that run the BIG tires and balance the driveline stresses the right way.
This is the 05 link      http://gearinstalls.com/flexor1a.htm
here's a shot of Chris's rig on the 42" I think...maybe 39"   http://gearinstalls.com/flexor1c.htm
« Last Edit: Jul 21, 2010, 04:01:56 PM by ZUK »
           www.gearinstalls.com
2001 White Xtracab Taco 3.4L Auto TRD
88 Runner/V6/auto/31"/5.29gear
Last post Jun 21, 2003, 08:56:58 AM
by toyotaboy
Last post Dec 10, 2004, 07:10:36 PM
by yotaboy79
Last post Aug 30, 2007, 09:19:41 AM
by Wermz84
Last post Jun 09, 2008, 09:55:06 PM
by Rocksurfer
Last post May 28, 2017, 11:51:37 AM
by brainlessfool
