What about 37x12.50x16.5?
The Wrangler Radials used on the HMV's over in Iraq.For $75 bucks a tire you cant pass it up.
who needs 17s , 15s are better
more rubber in the dirt and the 17 and bigger rims are just hype
an extra two inches of sidewall that has no tread or lugs on it is not going to benefit in the dirt at all! 17's are not hype at all. With a 17 you will get less of a sloshy or rolling feeling when you are aired down, when you air down you wont loose as much diff clearance, you can fit bigger brakes on your rig and now most companies are going to 17" rim size as a standard for 37" and bigger tires. obviously there are benefits if lots of tires companies dont even make larger tires to fit 15" rims any more.
so an 8.25" wide 16.5" tall wheel will correctly handle a 37x12.5 tire? I just figure you should be closer to 10" wide for that.
^ThisNarrow rims can help with keeping the bead seated before you need to upgrade to bead locks too. "Redneck Bead Locks"I think the rule of thumb though is try and keep the rims no more than 5" narrower than the tire.
Started by No Power General 4WD Discussion
Started by crawlerdan Parts For Sale
Started by robrub00 Parts Wanted
Started by Travis H Parts Wanted
Started by 81 yota Parts Wanted
