Author Topic: My axial 1/10 RTC W/HBZ warthog chassis  (Read 40533 times)
ToYocRawleR
  • Gettin' Loose!!
  • Turtle Points: 3
  • Male Posts: 3,110
  • Member since Oct '05
  • The Homie!!!
« on: Dec 21, 2009, 09:56:56 PM »
My wife got me the new axial ax10 RTC for x-mas  :cool: , thought id show it off....I already upgraded the steering to the aluminum links and changed out the pinion gear to a 12t and the spur gear to a 90t.  I want to get a dig tranny for it and some bigger tires but here it is as it stands, Let me know what yall think  :thumbs:
« Last Edit: Feb 02, 2010, 04:37:11 PM by ToYocRawleR »
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • Member since Dec '05
  • California livin'
Re: My axial 1/10 RTC
« Reply #1 on: Dec 21, 2009, 10:24:34 PM »
Nice! Welcome to the 1:10 addiction  :gap:
Do you plan to compete with this thing eventually? Personally, I think dig is a waste of money unless you plan to compete. My friend put it on one of his Axials and we wheel together regularly, and he rarely gets in a situation where he needs to use it. Don't get me wrong, it is nice to have. However for the money you'd spend, you could upgrade a lot of other stuff instead that will help you more often and in the long run. Either way, you are going to love this thing  :yesnod:
86rustbucket
  • Turtle Points: 45
  • Member since Jun '09
    • Buy me a soda
« Reply #2 on: Dec 21, 2009, 10:30:48 PM »
i think i want one thats what i think
ToYocRawleR [OP]
  • Gettin' Loose!!
  • Turtle Points: 3
  • Male Posts: 3,110
  • The Homie!!!
« Reply #3 on: Dec 21, 2009, 10:43:05 PM »
Yea i love it!! Way addicting!!  I actually do want to compete theres a few of my buddies that were talking about competing and i figured i would try it out and that i basically the only reason i want to get a dig but other than that what are some other upgrades you would recomend?
Rigs:
86rustbucket
  • Turtle Points: 45
    • Buy me a soda
« Reply #4 on: Dec 21, 2009, 10:47:41 PM »
and where is the cheapest place to get it?    and a battery/charger combo?
ToYocRawleR [OP]
  • Gettin' Loose!!
  • Turtle Points: 3
  • Male Posts: 3,110
  • The Homie!!!
« Reply #5 on: Dec 21, 2009, 10:49:41 PM »
I got mine from rcsuperstore.com, Another good site is ckrccrawlers.com
Rigs:
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • California livin'
« Reply #6 on: Dec 22, 2009, 12:58:45 PM »
You don't really have to upgrade anything if you don't want to, however as our rock courses evolved I quickly found the limitations to most stock axial parts. Mine is pretty indestructible now.
I'd upgrade:
The front C knuckles to clockable aluminum ones.
Aluminum steering knuckles
A hi-torque metal gear servo (axial servos crap out quick)
Aluminum bent lower links
Upgrade the upper 3 link y bars to aluminum and a 4 link (axle wrap is a PITA with a 3 link)
heavy duty metal driveshafts (I went through about 8 stock DS before I had enough and went metal, they strip and break easy)
Shock alum crossbar (adds rigidity to the chassis)
I would also lower your battery down and mount to the bottom of your battery plate instead of the top if you can move your electronics around. You'd be amazed at how much a difference that will make
Those are good tires, but by "today's" standards in the RC crawler world, they are small and there are a lot of bigger, better tires out there now. I rock the HB Rovers, and LOVE them. Big, wide, and grip all terrains excellently
BTA Steering (I don't have it, but it would be very nice)
Again, that seems like a pretty big list. Even though parts are cheap, it does add up quick. I would say prioritize certain upgrades as you wheel and break. Upgrade as you see fit. Some upgrades, like the battery placement, are free. I would say that is a pretty good list though in terms of what in the end, you are going to want to change.
ToYocRawleR [OP]
  • Gettin' Loose!!
  • Turtle Points: 3
  • Male Posts: 3,110
  • The Homie!!!
« Reply #7 on: Dec 22, 2009, 01:28:30 PM »
Sweet, Those are all upgrades i plan on doing for sure....what drivelines did you end up going with?
Rigs:
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • California livin'
« Reply #8 on: Dec 22, 2009, 01:53:02 PM »
I have the Integy HD shafts for the Axial, and they are great shafts for the price ($25), however, they require a little tweaking to get them to work right. I had to swap the all threads around and use locktite to keep them from coming out, but otherwise they are tough.
http://www.integy.com/cgi-bin/webc.cgi/st_prod.html?p_prodid=5839&p_catid=
I would recommend the MIP Ax10 CVD shafts however, they have beefy splines and are a higher quality than the Integy shafts. These are $40 a pair.
http://www.rcpcrawlers.com/product.php?productid=1015
4LoRunner
  • Turtle Points: -13
  • Male Posts: 680
  • Member since Dec '08
  • 109:1
    • Loaded Defense
    • Buy me a soda
« Reply #9 on: Dec 22, 2009, 03:12:35 PM »
Vent the rims with one 1/16" hole on the back side
Cut the fenders :gap:
Helpful mod i did was slip the bic pen tubes on the lower links (after you get them) and the tie rod. they work kinda like sliders, they cut down on the rocks grabbing into the alum.
and today im gonna go pick up the Hitec HS-5645MG Servo  :biggthumpup:
Sas'd '86 4Runner, 22RE-T, 4.88s, Dual Stock T-Cases, Locked F/R, 35" MTR's.
http://board.marlincrawler.com/index.php?topic=55751.0
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • California livin'
« Reply #10 on: Dec 22, 2009, 03:44:01 PM »
Good call!!! Forgot about those two free mods :)
4LoRunner
  • Male Posts: 680
  • 109:1
    • Loaded Defense
    • Buy me a soda
« Reply #11 on: Dec 22, 2009, 04:09:42 PM »
yep you told me about them both i believe haha
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • California livin'
« Reply #12 on: Dec 22, 2009, 04:16:48 PM »
 :smack:  :haha:
peacesells
  • Turtle Points: -17
  • Male Posts: 791
  • Member since Jul '08
  • motley lou
« Reply #13 on: Dec 22, 2009, 05:36:22 PM »
The best next to free upgrades besides those were move the lower links to the inside of the skidplate and inside of the axle brackets and replace the steering servo horn with a 3 hole aluminum one. I have it on the 2nd hole and it has way more steering tq with just as much turning angle.
I run a dig tranny and it is AWESOME!! I have 2 axials and I pretty much only drive the comp rig now just because of the dig. I use it all the time just because I can. There are lots of better upgrades to do first, but I love my dig...
this my man lysol, fresh out the joint
4LoRunner
  • Male Posts: 680
  • 109:1
    • Loaded Defense
    • Buy me a soda
« Reply #14 on: Dec 22, 2009, 09:08:39 PM »
question, could i cut the stock skidplate to move the links in or do i have to but the premade ones?
ToYocRawleR [OP]
  • Gettin' Loose!!
  • Turtle Points: 3
  • Male Posts: 3,110
  • The Homie!!!
« Reply #15 on: Dec 22, 2009, 10:27:33 PM »
Got any pics you could post of that? (Links inboarded)
Thanks for the input guys !  :thumbs:
Rigs:
lilbuddy
  • Dried Fruit Warrior
  • Turtle Points: -234
  • Male Posts: 5,720
  • Member since Aug '04
  • Hella....
« Reply #16 on: Dec 22, 2009, 10:30:37 PM »
if you need any parts you should hit me up... I work at A Main Hobbies now
RIP Kyota.... you are the man
GET IT!!!
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • California livin'
« Reply #17 on: Dec 23, 2009, 12:18:18 AM »
Yeah, you can just cut the stocker. I used an exacto knife. Here is what I did. I inboarded the links on the skidplate, while outboarding the shocks on the axle end.
4LoRunner
  • Male Posts: 680
  • 109:1
    • Loaded Defense
    • Buy me a soda
« Reply #18 on: Dec 23, 2009, 12:28:39 AM »
does that me we get a discount? heheh
4LoRunner
  • Male Posts: 680
  • 109:1
    • Loaded Defense
    • Buy me a soda
« Reply #19 on: Dec 23, 2009, 12:30:37 AM »
well to do that what do you need? spacers i know that and longer screws?
parts list please :greengrin:
« Last Edit: Dec 23, 2009, 12:38:44 AM by TON[Y]OTA »
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • California livin'
« Reply #20 on: Dec 23, 2009, 12:37:44 AM »
I used the stock screws IIRC (though longer may be necessary, did it a long time ago) and then cut the wider, mounting end of a few body posts to use as spacers. On the axle end, longer hardware is definitely required.
4LoRunner
  • Male Posts: 680
  • 109:1
    • Loaded Defense
    • Buy me a soda
« Reply #21 on: Dec 23, 2009, 12:40:58 AM »
reading that just made my brain numb haha im sorta tired at the moment so you might need to put it in simpler terms
snowshoebrue
  • Turtle Points: 447
  • Male Posts: 1,152
  • Member since Jun '05
« Reply #22 on: Dec 23, 2009, 10:06:21 AM »
i just did mine a couple days ago.  you will need to get  40mm long screws for the axle end to put the links outside the factory mount area.
4LoRunner
  • Male Posts: 680
  • 109:1
    • Loaded Defense
    • Buy me a soda
« Reply #23 on: Dec 23, 2009, 10:24:10 AM »
ok cool thanks :biggthumpup:
and for the ones where the skid plate, how long are those?
oh by the way, last night i was on RCCRAWLER.com and they have changed my mind from HB Rovers to HB Sedonas, check em out on RCCRAWLER.com
http://www.rccrawler.com/forum/showthread.php?t=197358
http://www.youtube.com/watch?v=atLodKCB5z8
ToYocRawleR [OP]
  • Gettin' Loose!!
  • Turtle Points: 3
  • Male Posts: 3,110
  • The Homie!!!
« Reply #24 on: Dec 23, 2009, 10:35:22 AM »
Sweet chris let me get your number again.
Thanks guys i wanna try this mod how does it work for all yall?
Rigs:
ToYocRawleR [OP]
  • Gettin' Loose!!
  • Turtle Points: 3
  • Male Posts: 3,110
  • The Homie!!!
« Reply #25 on: Dec 23, 2009, 10:36:27 AM »
Those tires look bitchin! Who sells em?
Rigs:
4LoRunner
  • Male Posts: 680
  • 109:1
    • Loaded Defense
    • Buy me a soda
« Reply #26 on: Dec 23, 2009, 10:52:24 AM »
well the best place to get em are at RPPHobby.com they have the best prices around only $17.99 a pair
always go to RPPHobby.com the will beat anybody's prices, spread the word!
the only thing is that Hot Bodies (manufacturer) hasn't released a release date yet hopefully Jan or Feb
http://www.rpphobby.com/product_p/hbs67918.htm
peacesells
  • Male Posts: 791
  • motley lou
« Reply #27 on: Dec 23, 2009, 12:31:22 PM »
Yes you can just cut the stock one, thats all I did. I will try to find some pics
peacesells
  • Male Posts: 791
  • motley lou
« Reply #28 on: Dec 23, 2009, 12:39:02 PM »
Here is a link for the ckrc stage 2 build, most of the mods you can piece together at ace hardware. It tells how to cut the skidplate and swap the shock bumpers, another good free mod.
http://www.rccrawler.com/axialcompbuild.html
snowshoebrue
  • Male Posts: 1,152
« Reply #29 on: Dec 23, 2009, 05:59:51 PM »
i would still buy the rovers.  you can get 4 for 17 from rpp.  then you will have 2 sets of awesome tires when you buy your sedonna's
Last post Feb 01, 2009, 07:01:31 PM
by 46&2
Last post Jan 02, 2009, 09:07:29 AM
by flexinup
Last post Jun 29, 2009, 11:29:44 PM
by AaronB
Last post May 11, 2012, 11:53:55 PM
by 4.3yota
Last post Aug 03, 2015, 12:56:50 PM
by 541mudder
