Author Topic: "Old Red" 84 build --> Dual cases and Lift in progress  (Read 10050 times)
Dark Knight
  • Turtle Points: -4
  • Male Posts: 133
  • Member since Sep '09
  • 88 SR5
« on: Sep 11, 2009, 05:57:25 AM »
Just getting started on this. I'm stoked too have figured out my brake problem, now it's time to get started on moving forward with the build.
here are some pics of what I'm starting with
I thought it was a brake booster problem that was causing my brakes to grab and lock up front, turns out when I took the master cylinder off the booster it looked like the pin was way to long, I adjusted it back about 1/8th inch and put everything back together. It has worked like a charm. the pin being to long was not allowing the master cylinder to fully rest making the brakes grab/heat up/lock up.
Next up on the list is to take out the front axle and rebuild it
Any suggestions which direction I should go first, after the axle is done?
« Last Edit: Nov 13, 2009, 09:39:12 AM by Dark Knight »
Yota-Freak
  • Male Posts: 469
  • Member since Jul '08
  • Pass tha' whiskey and that rot gut Shine.
Re: "Old Red" 84 build
« Reply #1 on: Sep 11, 2009, 09:57:15 AM »
clean rig dude, looks perfect besides the passenger front fender. what are your plans for her?
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
« Reply #2 on: Sep 11, 2009, 10:56:48 AM »
thanks man. both front fenders are a little ate up but nothing too bad. I have so many plans I dont know where to start.
Here is a short list of what I think are most important in order of how I would like the build to go:
1. rebuild front axle
2. crawler box or *4.70 gear set, probably the gear set.
3. Eaton Elocker F/R
4. 5" trail-flex lift kit
5. 35" tires with black crawler wheels
6. rebuild engine (only has 132,000 on the clock right now)
7. front/rear custom bumpers w/ front winch and sliders
8. custom tube bed
and so on....... The list above should take somewhere in the neighborhood of 3 years to get the money and time to build for all that stuff
Edit:*
« Last Edit: Sep 11, 2009, 11:13:19 AM by Dark Knight »
Yota-Freak
  • Male Posts: 469
« Reply #3 on: Sep 11, 2009, 06:15:09 PM »
haha i feel ya, sounds nice...at least ur starting with a SFA....i gotta convert which is a good chunk of change. any gear reduction in your diffs? u gunna run stock gearing or no?
Halladay
  • Member since May '09
  • HALLADAY
« Reply #4 on: Sep 13, 2009, 03:24:02 PM »
Rock the I.F.S that what all the real men are doin on the trails these days!!!!
Yota-Freak
  • Male Posts: 469
« Reply #5 on: Sep 13, 2009, 03:45:16 PM »
well im a real man, im 100% sure about that...i just dont have the money to keep buyin Half shafts all the damn time. lol...plus its such a rough ride (with the lift) not to mention ZERO flex
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
« Reply #6 on: Sep 13, 2009, 06:51:03 PM »
yes a re-gear is planed, maybe 4.88 or 5.29's but I have not done enough research on that to make a decision yet. I'll probably do the re-gear at the same time as the Elockers.
Yota-Freak
  • Male Posts: 469
« Reply #7 on: Sep 13, 2009, 07:57:53 PM »
well id roll with 5.29s if i were you...there the same price and you can run some huge tires....unless ur not going anybigger than like 35's then id just stick with 4.88's....but if you plan on goin bigger anytime down the road, 5.29's will save you labor,time and money
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
« Reply #8 on: Sep 15, 2009, 09:23:50 AM »
I'm thinking through how I want to do my lift. here is what I'm thinking.
For the rear I am going to do chevy 63" with double shackles in back.
My thoughts on the front was this: I have easy access to 3" Skyjacker springs. these springs are made to be a direct replacement lift spring for a stock SFA pickup. If I use these Skyjacker 3" springs and weld in the Marlin front spring hanger kit, I will get right at 4" of front lift. Is this sound reasoning? will this setup fit 35" tires?
Or I can get the Skyjacker 5" front springs and not do the front spring hanger kit, but probably still replace the factory shackles. I'm fairly certain this way would fit 35" tires. Also going with the 5" springs I would use an AAL in the 63" chevys to make everything sit nice and level.
Thoughts on this??......
Yota-Freak
  • Male Posts: 469
« Reply #9 on: Sep 15, 2009, 09:30:20 AM »
all i gotta say is....dont get dual shackles. you will get axle wrap like a mofo! as for the 4in lift fittin 35's....im sure you can, but you might be hitting some body parts when you turn....i had to cut my fenders so i didnt rub on turns and im rockin 33's
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
« Reply #10 on: Sep 15, 2009, 09:39:14 AM »
I have seen some "L" shaped shackles that may fix that problem. Where can I find those?
also with the rubbing, wheel backspacing/offset has a ton to do with that. what backspacing are your wheels freak?
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
« Reply #11 on: Sep 16, 2009, 09:26:05 AM »
!! "boomerang" shackles
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
  • Member since Jul '05
« Reply #12 on: Sep 16, 2009, 01:04:10 PM »
I would use your main leaves from the rear springs up front with that hangar - then build a leaf pack with the skyjakers to get the lift you want.  This will move the center pin of your axle 1" forward and another  1.5inches forward with marlin's spring hangar.  This should help with firewall clearance for 35" tires.
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
« Reply #13 on: Sep 16, 2009, 01:14:06 PM »
I was going to ask what type of front drive shaft mods would be needed but that all depends on whether I just go with the 4.70's in the stock transfer case or go for a dual case set up.....
Halladay
  • HALLADAY
« Reply #14 on: Sep 16, 2009, 10:09:27 PM »
if you went 4.7s with a stock case you wont need anything. maybe just upgrade it with a stronger/more spline driveline. i know trail gear makes one with long travle splines....
with duals you will have to shorten yours. when i did my duals i took my driveline to DriveLine Tech. The guy owns the shop all by himself and does amazing work. he made my driveline out of .250 DOM. strong as you will ever need i payed 200 bucks i think and i gave him my front driveline i had from my IFS cause it had a CV and he put the CV in the rear cause its a Short Steep angle.
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
« Reply #15 on: Sep 18, 2009, 06:01:23 AM »
Does anyone make a front spring hanger that does not move the springs any further forward? I know I could fab one myself but i dont have the equipment. Or is it just a matter of where you place the hanger when welding? With the RUF I'll be going far enough to fit 35's. my goal here with the final product is to be on 35's and be as low as possible with the lift.....
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
« Reply #16 on: Sep 18, 2009, 07:08:37 AM »
You want to move the springs forward if you are trying to fit 35's with minimal lift.  It will help keep the tires from rubbing the firewall.  Trust me, I tried driving on my 35's with stock springs, fiberglass fenders and a small shackle lift in the front and the rubbing was out of control.  So I hamered down the pinch weld and it still rubbed.  You could always have Alcan custom build you some to your specs....
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
« Reply #17 on: Sep 18, 2009, 07:22:11 AM »
the rears up front will move the axle forward right? the reason I was curious about the hanger is to have better pinion angle.
Halladay
  • HALLADAY
« Reply #18 on: Sep 18, 2009, 07:35:43 AM »
yes they will a little bit. thats what i have in my truck. if you wanna see how much forward check out my build up.
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
« Reply #19 on: Sep 28, 2009, 01:58:16 PM »
What numbers in the vin will tell you which transmission is in the truck? or what is the easiest way to figure this out?
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
« Reply #20 on: Sep 28, 2009, 03:49:47 PM »
Check out this off of Marlin's trans page http://marlincrawler.com/transmission/rebuilt-complete
Just look at your trans and match it up to one in the picture.
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
« Reply #21 on: Oct 12, 2009, 06:52:11 AM »
tore into the front axle last night. driver side looks pretty good. The passenger side had been messed with before, It is missing the large spring in the locking hub and the hub clutch is thrashed :smack: so I need to find those two parts. There was little pieces of metal in the hub from the clutch, one little piece was imbeded in the hub not allowing the hub clutch to be removed, I got that cleaned up as good as I could. and the passenger side is torn down to the spindle. Hope I dont find anything else retarded on the passenger side :cheese:
I couldnt find part numbers for the hub clutch and spring, anyone help with this??
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
cant seem to get the hub back on the passenger side.... why does it seem like the inner bearing will not go all the way up on the spindle.... Ideas?
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
Re: "Old Red" 84 build --> Help!!
« Reply #23 on: Oct 21, 2009, 06:16:41 AM »
Knuckle rebuild is finished!   :gap: Turned out great for my first time doing it. I didnt paint anything this go'round but atleast I'm not leaking any more gear oil at the moment. Tonight I will tackle changing out the clutch slave cylinder and be done with the truck till next spring. Hopefully through the winter I can save enough money to get 5.29's and lockers front and rear, (I'll also clean up the front axle a little better while installing the lockers and R&P's), get some sort of 4" lift together, 35" tire w/ 15x8 wheels, high steer setup, crawler box, and new drive lines.
CrazyYota
  • Turtle Points: 92
  • Male Posts: 1,073
  • Member since Oct '05
« Reply #24 on: Oct 21, 2009, 10:45:41 AM »
This will help identify your transmission. :thumbs: just pop the hood and look.
axled89
  • Turtle Points: 296
  • Male Posts: 2,526
  • Member since Jan '09
« Reply #25 on: Oct 21, 2009, 10:56:49 AM »
good info. to have  :beerchug:
i love oregon wheelin.
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
« Reply #26 on: Oct 21, 2009, 12:07:10 PM »
holy crap thats awesome crazyYota thanks for that!
CrazyYota
  • Turtle Points: 92
  • Male Posts: 1,073
Re: "Old Red" 84 build --> Knuckles finished!
« Reply #27 on: Oct 21, 2009, 04:48:09 PM »
8)
Halladay
  • HALLADAY
« Reply #28 on: Oct 21, 2009, 09:29:21 PM »
that should get you rollin  :banana:
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
« Reply #29 on: Nov 13, 2009, 09:32:02 AM »
dual cases:
Just bought a top shift from a member here. My current t-case if a forward shift (g52). am I going to have to convert the current forward shift to top shift? Or, can I just leave the forward shift in front and bolt the top shift reduction box and adapter in between the right hand drop case and the forward shift?
Last post May 18, 2006, 11:06:44 PM
by scyota
Last post Jul 26, 2006, 06:04:53 PM
by Broke_Okie_Ty
Last post Oct 05, 2011, 04:02:49 PM
by Shamb
Last post Jul 17, 2008, 05:25:15 AM
by 79-83earlyota
Last post Mar 02, 2023, 11:21:58 PM
by dms3
