Got my Marlin package yesterday but was sad to see a stock OEM mount in the box rather than the 4x Innovations mount. I PM'ed Andrew Butler in the Customer Support Board section about my order.
Sounds like you got more than you paid for...
Mounted mine last Friday,but it came of twice as fast I understand that it is a HD mount,but there has to be something between the oem and this one.Way too stiff bushings,everything inside and outside vibrated at idle,and it went worse as the rpm went higher. So for a DD it is no no for me ,softer bushings would maybe fix the problem
i love my 4x innovations mount except for the welds that hold the tubing on are . mine broke a month ago from giving someone a pretty decent pull. i admit i was being hard on it and its been through many wheelin trips, but if it were welded right it wouldn't have broke. it broke right at the toes of the weld were there was major undercut, the welds are also extremely small, there technically thick enough to be sound but the way they are laid in there isnt sufficient since its really tight flared butt joint, the weld has to be a decent size to get rid of the sharp edge and undercut. wasn't hard to fix, but just a pain in the ass couse i had to take it out. i just clamped it back to the original position and then laid a new bead over it. while i had it out i went ahead and did the other spots on it because they also had major undercut. so far its been fine. havent been on to many trips since then but im pretty sure it will be good to go now. heres some pics i took of were it broke, hard to see since there just cell phone pics but its all i have.
You know trail geag has some to with different style of bushings may be they used rubber on theres they are in the crossmember section
You know trail geag has copied every other innovative product in this market with no regard to intellectual property or moral regard to the small hobbyist people perhaps much like yourself who work so hard and put up all their life savings at building their dreams only to see them get taken with no permission or finical reimbursement.Thanks.
Matt,I wish you would have called me when you broke your mount so we could discuss how it happened and fix the issue for you...Couldn't have said it better.
Started by SLIVER Engine
Started by Dark Knight Parts Wanted
Started by vaj70cruiser Parts For Sale
Started by COToy91 Parts For Sale
