i know, i was not trying to be an ace sorry. I have not heard of it but i bet you could really easily. Trying to see it in my mind. i think you could attach the ram to your inner frame? like Marlin's steering stabilizer
NO they are not the same. If you have a Toyota box, PS fluid will make it leak....I seen it happen Your owners manual specifies ATF only for the power steering system
Scott- be patient. It took me 4 DAYS of bleeding every few hours to work properly. Also, as a note, the ram really needs the pump to be in high pressure to work correctly. If the wheels are off the ground that happens when you hit the stops. Sorry if you already knew that, but just wanted to make sure.
Started by fabtoys Project Research and Build-Ups
Started by KYOTA General 4WD Discussion
Started by bjwest Toyota Pickup/4Runner Tech 1979-95
Started by axled89 Axle/Differential/Steering
Started by supermoto917 Axle/Differential/Steering
