Mikey, please tell me that you weren't using a chunk of railroad tie, ontop of a steel brick, on top of a bucket for a jackstand (last picture in your shackle sequence).
the 3RZ is MUCH taller than a 22R, so the pan sits very low. So I think they only way to get around this will be to change my springs and run our Marlin front springs
p.s. I use the 4x4 wood as lift for the jack all the time! so don't worry, your in good company
Two words for ya mikey, HOOD LIFT!
You're close - actually its a 3 ton jack, then two 2" aluminum bars I found, and then a piece of 4x4 wood. It was the only way to get the jack high enough to reach the frame. I did however place some quarters on both sides of the wheels of the jack so that it won't move Safety first
Hey BigMike, did I see correcly, you took the body off your rig, Are starting over?
Nope, right now I am saving up some $$ for my summer project
Hey Mike wondering if you received my post
1 Will it clear a FJ-80 HP front diff? with the housing moved forward 2"[/url]
2 Will a rf151 turbo tranny bolt to the W 59 bellhsg
3 Can you send me a total parts list? please!
4 Sounds like the 2.7 needs to be from a T-100 or gather the pan assembly? for non T-100
5 How close to the fire wall should I mount the motor for fan, rad clearance? Also should I mount motor higher for axle clearance?
6 Do you hear feed back that the FJ-80 E locker is strong and reliable enough to handle 37" MTRs? What about Taco Rear TRD?
7 Is FJ-80 63"wms to wms? Is TAco 61" wms to wms?
Don't you know it's bad luck to take a flash picture inside the cab while driving at 70 MPH.
Started by Mike D Engine
Started by gturismo Chit Chat Camp
Started by BigMike « 1 2 ... 18 19 » Project Research and Build-Ups
Started by BigMike « 1 2 ... 11 12 » Trail Reports, Events, and Gatherings
Started by BigMike « 1 2 3 » Trail Reports, Events, and Gatherings
