Just about everyone knows the quality of Marlin as a person,so here's another great story to add to the many,taken right out of the TTORA board from this past weekend:for the book but I feel this story should be told. I drove over 1700 miles (one-way) in my red '01 Tundra to meet, party and wheel with ya all and instead I met up with ole man Murphy and he kicked my ass a little. I had previously e-mailed Mike and advised I would be late getting to the starting gate but I would catch up to the group before Buck Lake. I've done the Rubicon previously with this Tundra and I felt I could easily make up a couple hours on a large group. My rig is 3-linked up front with a Spidertrac 9" housing and tubes with a Hi9 3rd - solid axle 60 knuckles and C's on the corners and Bobby's Dana 60 birfs and axles, 4-linked rear with the same housing and 3rd member, ARB lockers and coilovers all around on 35" Krawlers. She's also got the Marlin Crawler 4.7 coupled to a Taco V6 transfer case with twin sticks (done by Marlin) and is well armored. I was planning on running everything clean as a whistle and hoping I could get a good spot from one of you through little sluice, as I didn't attempt that puppy last time around. Well, everything was going fine and I had just breezed up Walker hill and on that little tiny good for nothing rock pile about a quarter mile west of little sluice I broke the output shaft on my transfer case. I was dead in the water and flat flopped at that point. I'm grateful to Matt (a TTora member) who came along and winched me back to a location off the trail so others could get past. (I was monitoring the CB ch and heard the last group was just talking about taking the bypass around little sluice, so I was real close at that point to catching up.) I then called Richard Stubbs who advised he would make a couple calls looking for my type of set up and upon locating one he would be on his way. He suggested I call Marlin and get some parts coming his way as a backup. I then called Marlin and after explaining my dilemma he just flat out stated "It will take me a couple hours to finish up a project here, load my truck up with everything you might need and I'll be on my way to your location." Marlin has a reputation second to none for customer service and is well respected in the 4X4 community as you all know but this type of service from anyone but Marlin is unheard of. I then called Stubbs back and advised Marlin was on his way to which Richard replied something like I would expect that from Marlin as thats just the way that guy does business. I then got back to Marlin about an hour later and advised Marlin that a rig needed an 80 series tie rod end and he said he would pack a couple ends along and other parts for anyone else needing parts that he stocks. Marlin showed up with enough parts and equipment to sink a battleship. What a terrific person he is, on his way to me he and James (a friend of Marlin's and a great guy) stopped and repaired a couple of jeeps, as one needed his driveshaft welded while the other snapped an axle, which both were welded back into working condition. He then swaps out my transfer case after taking a look at the crawler, which was still in perfect shape. (Marlin advised he's only seen one other snapped output shaft like mine - that was on richard Foster's rig - so you're not alone out there richard) On our way out we roll up on a group of jeeps from Arizona and a guy walks up to Marlin with a sad face and asks "you wouldn't just happen to have an on-bound welder would you?" They snapped an axle, which Marlin welded up and everything was good with the group in less than half an hour and everyone was grateful for Marlins help and expertise. The guy owning the broke jeep offered Marlin $$$$ and in his typical style he would say "If you put that damn money back in your pocket I will shake your hand." He absolutely refused to accept money from anyone, including me. He spent a lot of money just for gas on this rescue mission let alone his time and expertise. I somehow will make it right with Marlin even though I know he will give me over it. He and his shop, Marlin Crawler, http://www.marlincrawler.com/ will always be the best of the best in my book. Wish I could have caught up with you guys but maybe next year Ill get to the starting gate on time, mean while just join me in letting everyone know that Marlin Crawler customer service is the best on the planet.Joe
Marlin requested time off and after a short shop meeting, was granted permission
That is why I buy from the man. :yesnod:Just strikes me funny when "Marlin" has to request time off from working at "Marlin Crawler"
I heard about that from Joe. TREs are simple enough to carry and yet even I don't have one. I think your experience has also motivated me to do the same.The last time I ran Dusy, I rolled my passengers front outer beed off the rim without knowing and continued to drive. It was in a very slow and technical area, so I didn't exactly go far with it like that, but I noticed that my drivers front tire seemed to be working really hard for traction. That is when I got out and discovered the cause.Because I drove on it like that, I ended up damaging a valve steam. A simple little valve stem. I had to use permatex and sand paper to get it to seat properly, and even was unsure if it would stay in place once air pressure returned.Well, my permatex fix got me home safely, and now I carry like 10 valve stems.It's sometimes the small little stuff that can ruin an entire weekend! And the crazy thing is that Marlin always seems to have everything needed for a proper repair.
MC could just do that every 2-3 months and do enough word of mouth advertizing to probably open a second shop in a short time iof they wanted to
In his usual fashion, Marlin requested time off and after a short shop meeting, was granted permission to help the customer on the trail. Marlin checked his truck over and began loading it. At this point we are not sure what broke, so spare parts were gathered including a good used chain drive t/case.
Started by snorklehead General 4WD Discussion
Started by rEdnECkwHeE1eR General 4WD Discussion
Started by stevemcgee99 Parts For Sale
Started by mojavehanna Parts For Sale
Started by BigMike New Announcements and Info
