...why buy when you can build?
I think I found where my bronze came from in my oil filter. There are weird wear marks on the little sleve that the lower t-chain gear sits on. looks like it has been moving... .PZ
he said it was moving, the idiot that rebuilt his engine either used standard size thrust bearings or didn't know what they werethe thrust bearings are 4 cresent moon shaped strips that got between the #3 main and the crank
Alright. I am not sure if it was the or the light, but those large chunks were RTV. other than that there was like 2 small slivers of metal and that was it. Other than that the oil was clean of metal. Now I am pretty positive that its the t-chain, but I am going out in a few to check the end play in the crank. I heard that it should have .007-.010 endplay.I am thinking about this kit for the t-chainhttp://www.toyotacatalog.net/M1WebGear/ProductDetails.aspx?PartID=1015012&PartRevisionID=Its a little $$$ but it would be nice to have a dual row. I was wondering if you can do this with the stock timing cover, but their website says you can'tPZ
hey i just got done reading through your whole predicament here. i recently rebuilt my 22r. i put a 20r head on it and used a double row timing chain. i've had no rubbing issues. but i dont know if the timing cover on a 22r and a 22re are the same. if they are the same i wouldnt see y using a double row chain would be an issue. and the reason i rebuilt my engine is because my thrust washers went bad. when that happened i had lots of metal in my oil pan, so i dont think that the thrust washers are your problem. it is also not uncommon to see small shavings of metal in your oil soon after a complete rebuild. the crank bearings have to break in and this will cause small amounts of metal in your oil. thats why it is recommended to change your oil soon after a rebuild. hopefully some of that info can help you out!
Started by traveler727 Engine
Started by Plowking Project Research and Build-Ups
Started by KDXSR5 « 1 2 » Chit Chat Camp
Started by deepsouth Engine
Started by Plowking Parts Wanted
