Author Topic: EGR issues. Need some help  (Read 57389 times)
Yota4life
  • Turtle Points: -128
  • Male Posts: 1,461
  • Member since Nov '04
Re: EGR issues. Need some help
« Reply #60 on: Jan 16, 2010, 10:28:35 PM »
haha good one. I bought a magnaflow cat for 1999 tacomas and put it on my 88 do you think that could be why my NOX reading was so high on smog?
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #61 on: Jan 16, 2010, 10:35:05 PM »
No, I'd bet on the lack of backpressure...........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Yota4life
  • Male Posts: 1,461
« Reply #62 on: Jan 17, 2010, 12:48:18 AM »
my CO% was almost ZERO so i must need a new o2 sensor and ill try plugging the exhaust some and go from there. but if the egr hasent been working the whole time that must be why i get horrible gas mileage. My 22re sucks gas like a big block
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Yota4life
  • Male Posts: 1,461
« Reply #64 on: Jan 17, 2010, 01:26:58 PM »
That explains a lot... Do you think the egr modulator can go bad? i checked mine and its clean.
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #65 on: Jan 17, 2010, 03:16:13 PM »
They can, but I doubt it.
Without backpressure on the bottom diaphragm, the EGR won't work.    You can test for leaks.....
Remove that hose, and plug in a fuel pressure gauge with a long hose so you can monitor the back pressure while driving.
You need to see at least 1/2 psi at the 25mph 2nd gear, steady speed for there to be EGR to lower the NOX.
With my 86,  it just fluttered a little until I added my 'special' back pressure gasket and it went to about 1 psi....  (this is how I aced the NOX last smog test)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Yota4life
  • Male Posts: 1,461
« Reply #66 on: Jan 17, 2010, 04:21:10 PM »
I have a flange between my down pipe and cat. Im going to make a plate and try your back pressure trick for my next test. I should be good to go after that with a new o2 sensor and some denatured alcohol in the tank :)
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #67 on: Jan 17, 2010, 07:14:51 PM »
Retard timing 2.5 degrees (you're allowed +- 3 from stock)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Yota4life
  • Male Posts: 1,461
« Reply #68 on: Jan 17, 2010, 10:00:08 PM »
i was going to do that also. I guess my timming was at 6* my first test
Yota4life
  • Male Posts: 1,461
« Reply #69 on: Jan 23, 2010, 03:55:58 PM »
i did a retest today and with a exhaust plate with a 1.25" hole in it i got closer to passing but still failed. SO i need a better CA legal cat and i should pass fine... thats all i can think of to do now.
954toy
  • Male Posts: 15
  • Member since Oct '10
  • One foot on the gas, One foot in the grave.
« Reply #70 on: Oct 20, 2010, 07:28:51 PM »
how did you do? what was your fix?
‎"If you don't stay out late drinking on Saturday night; you ain't got nothing to talk to Jesus about on Sunday morning"
ascdub
  • Turtle Points: 32
  • Male Posts: 41
  • Member since Nov '08
« Reply #71 on: Jul 02, 2011, 09:53:35 AM »
wow good article time to start on the checklist everything in this post are alot of the problems i've been having. Does the airflow meter have any effect on this problem?
Last post Oct 31, 2005, 06:15:18 PM
by *FFC*
Last post Dec 25, 2005, 08:57:44 PM
by skid
Last post Dec 19, 2005, 11:44:56 PM
by RustyToy
Last post Jan 15, 2006, 05:46:18 PM
by kneedownnate
Last post Apr 23, 2023, 01:12:41 PM
by boredmuse
