Author Topic: Hydro Assist:box and pump mods  (Read 339653 times)
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
  • Member since Nov '04
    • PhotoBucket
Re: Hydro Assist:box and pump mods
« Reply #150 on: Dec 14, 2006, 07:10:37 PM »
Anyone think this idea would work...
In effect, would isolate the RAM unless the valves where open, and would allow the RAM to run in a closed loop when valves where shut which would allow the RAM to move freely against the stock steering box pressure... almost like a steering dampner if anything.
Just seems like this might be a good idea for a daily driver.  No change on road (valves closed) and full ability to crawl with low PSI, etc off road (valves open).  Off course this assumes such valves are even available.
It would work, but, as previously stated, that is a lot of drag.  The ram has to circulate fluid from one side, through the hoses, to the other side.
And yes, valves are available.
Yota4life
  • Turtle Points: -128
  • Male Posts: 1,461
« Reply #151 on: Jan 10, 2007, 09:05:12 AM »
Here is a picture of the modified P.S. reservoir and the cooler I installed on Rokcrawlintoy's rig. No squeeling and it stays cool.
Where did you buy the cooler and how much? Thanks much
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
  • Member since May '05
« Reply #152 on: Jan 10, 2007, 09:13:43 AM »
Yota4life-
I bought the cooler from PAW 818-678-3000
It was 27.95 and came with the low pressure hoses.
It is a Hayden Part # 401 which you can also get from JEGS and SUMMIT.  :beer:
« Last Edit: Jan 10, 2007, 11:07:12 AM by 4X Flyin »
82 1st Gen with 4.3L vortec and 4l60e. Linked front and rear
My build up. Getting linked
http://board.marlincrawler.com/index.php?topic=50700.msg711361#msg711361
Yota4life
  • Male Posts: 1,461
« Reply #153 on: Jan 10, 2007, 09:22:38 AM »
I couldnt find it on jegs or summit...??  :confused:
« Last Edit: Jan 10, 2007, 09:58:19 AM by Yota4life »
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
« Reply #154 on: Jan 10, 2007, 11:06:32 AM »
Yota4life-
Jegs part # for the equivalent from Flexalite is #400-3810 @ $26.99
http://www.jegs.com/webapp/wcs/stores/servlet/productitem_10001_10002_756324_-1_311512
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
« Reply #155 on: Jan 10, 2007, 12:05:43 PM »
The hose's from Surplus Center come with ends on them, they only run about 8 bucks too.
that reminds me I need to get a couple a spares. After the last trip I noticed on of my lines had been getting :bumpinbutts: bettween the bumpstop and one of the u bolts and got tore up pretty good. Those hoses just arent something you can ask "Hey you got an extra hydro hose?" out on the trail. You'd be pretty much screwed.
KYOTA
  • Wreckin Ball '09
« Reply #156 on: Jan 10, 2007, 12:09:25 PM »
I've got an IFS box that I bought second hand, pre-tapped...
when looking into the empty box, it looks like the fitting in the "TOYODA" will be hit by the sector shaft gears as you turn.
is that a problem for anyone?
Tapped the hole too deep, I did the same thing and yes it hit. Easy fix, pull the fitting and grind the threads down and reinstall, keep doing this till the fitting is tight and will clear the gear
Tice
  • Turtle Points: 8
  • Male Posts: 881
  • Member since Feb '05
  • I named my son Wheeler!!!!
« Reply #157 on: Jan 10, 2007, 02:17:49 PM »
I'm glad you said that, I've been saying for months now that I need spares!!!. :disturbed:
I don't need a winch, I wheel a TOYOTA!!!!!!!
www.wheelingarizona.com
watkins
  • I love Marlin Crawler!
« Reply #158 on: Jan 17, 2007, 09:02:55 AM »
Turn the input shaft to the left until it stops. Now remove the 4 input shaft housing bolts.
keeping the input turned to the left helps keep it together.  Mine had some water contamination and while spraying it out with brake cleaner I turned the input to the right a little to far and OOPS! damn ball bearings went everywhere when it came apart! only way i found to get them back in was to take the 2 piece tube out and work them back in until full, then using 1 of the tube pieces and turning the assembly up sideways as to get the tube level horizontly put the rest of the bearings in and slowly work the other half of the tube in and secure it. wish i had counted all the ball bearings but forgot, hope i found all of them!
great write up on the box!
wade
alwayzbroken
  • Turtle Points: 603
  • Male Posts: 1,905
« Reply #159 on: Jan 17, 2007, 10:24:29 AM »
I wrapped my hoses with heater hose so they are protected. I did this after wrecking one hose. So far works like a champ.
alwayzbroken
  • Male Posts: 1,905
« Reply #160 on: Jan 17, 2007, 10:26:36 AM »
wade
Post up when your box fails. I predict the balls will get pulverized and leave you with no steering.
watkins
« Reply #161 on: Jan 17, 2007, 07:22:05 PM »
daaaaaannnng! pulverizing my balls is not good! maybe, maybe not!
the tube i refer to limits how far in and out the balls can go. after i figured that out i believe after i got them all in i'll be OK. we'll see. it was a high mile box but it was tight and had no leaks. i'll post on it later.
wade
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #162 on: Jan 21, 2007, 09:29:15 PM »
i didn't read it in this thread but is anyone running any type of sealing stuff like teflon tape on the threads of the fittings and ram?  i just got my box tapped and was wondering if it is needed or not.
- Sales Employee -
freds40 [OP]
  • Turtle Points: 293
  • Male Posts: 2,331
  • Member since Dec '02
« Reply #163 on: Jan 21, 2007, 10:17:39 PM »
You shouldn't need t-tape. NPT fittings are taper seat fittings so they seal on themselves. If you throw t-tape on, it shouldn't matter.
"between projects"
  • I'm Legit!!!
  • Male Posts: 6,715
  • AKA Baja Brad
« Reply #164 on: Jan 21, 2007, 10:28:14 PM »
ok, thanx dude.
Tice
  • Turtle Points: 8
  • Male Posts: 881
« Reply #165 on: Jan 22, 2007, 10:15:21 AM »
I had to use tape on one fitting, but it was my fault. :smack:
alwayzbroken
  • Male Posts: 1,905
« Reply #166 on: Jan 22, 2007, 10:49:48 AM »
I have done two boxes with no tape and no leaks.
Yota4life
  • Male Posts: 1,461
« Reply #167 on: Jan 23, 2007, 06:59:43 PM »
Im having a problem with the restrictor. I cant get the bushing to come out. I was slamming it hard on a steel table and couldnt get it to budge. Any pointers?
Tice
  • Turtle Points: 8
  • Male Posts: 881
« Reply #168 on: Jan 23, 2007, 08:45:14 PM »
It should just fall out!! :dunno:  Miine did. But after drilling it out, it made my pump squel really bad at 1000 rpm's and higher. Plus I would have to have the rpm's up for my ram to work!! :dunno:  Try it in stock form first and see how it works. I know if it doesn't them you'll have to take it apart and bled the system again.  Also,I have my modified one still I just have to remember where I put it!! :smack: So if you can't get the bushing out you can have mine.  Just throw down a few bucks for shipping. :thumbs:
Yota4life
  • Male Posts: 1,461
« Reply #169 on: Jan 23, 2007, 10:08:40 PM »
Well i turned it upside down and stuck a rod in there and hit it with the hammer and there was a little peice that had 2 holes in it and that just broke out. So i might have just ruined it but i still cant get it out. I might take you up on that Tice
Tice
  • Turtle Points: 8
  • Male Posts: 881
« Reply #170 on: Jan 24, 2007, 05:42:04 AM »
Not a problem, Let me look for it today after I get home from work. :beerchug:
KYOTA
  • Wreckin Ball '09
« Reply #171 on: Jan 24, 2007, 03:02:51 PM »
my spares showed up today have you ordered yours?  :greengrin:
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
« Reply #172 on: Jan 24, 2007, 04:17:55 PM »
i love this setup, and when i get some spare funds after the longs, this is next on my list
Tice
  • Turtle Points: 8
  • Male Posts: 881
« Reply #173 on: Jan 24, 2007, 05:54:09 PM »
 :smack: No,  :hammerhead:
Tice
  • Turtle Points: 8
  • Male Posts: 881
« Reply #174 on: Jan 25, 2007, 06:56:42 PM »
Shoot me a p.m. with your address if you want it. I haven't had a chance to look for it but I think I know where it's at.
Yota4life
  • Male Posts: 1,461
« Reply #175 on: Jan 25, 2007, 07:34:15 PM »
You know what im going to drill it out with the bushing in there and run it. If it dosent work then i will let you know. Thanks a lot though i might need it
Tice
  • Turtle Points: 8
  • Male Posts: 881
« Reply #176 on: Jan 25, 2007, 08:06:20 PM »
Any time! :beer:
Burl
  • Turtle Points: 271
  • Male Posts: 389
  • Member since Jan '07
  • Wannabe Smokejumper
« Reply #177 on: Jan 26, 2007, 11:43:19 AM »
This is an in depth layout of how I have drilled/tapped Toyota IFS steering boxes for Hydro assist as well as a simple mod to allow your pump to keep up. I was able to get ahold of a box (thanks toecutter) so I could show a bit more detail than my original thread on just setting up my system. This is intended to give a bit more info on the time, tools, and ability needed to do this mod. I was nervous about it the first time but once I got into it, I was upset at how difficult many people made the job sound. If you want to give me $75 to do your box, that's fine but this is not about me making money, it's to show that it can be done easily by most people. It took me about 2 hrs. from start to finish and that was with taking all the pictures. So if you have the ability, a bit of patience, and don't have the cash to have someone elso do it, try it yourself.
And this is the rest of setting up my Hydro assist system for cheap.   http://board.marlincrawler.com/index.php?topic=4699.0
alwayzbroken
  • Male Posts: 1,905
« Reply #178 on: Jan 26, 2007, 12:26:22 PM »
It sounds like you have a 3rd gen pump and that is how the restrictor is. That is what you were supposed to drill out but you broke it instead.
Yota4life
  • Male Posts: 1,461
« Reply #179 on: Jan 26, 2007, 03:52:37 PM »
Ya thats what i was thinking. Cool i guess i will just throw it back in and run it.
Last post Jan 29, 2006, 08:49:05 PM
by KYOTA
Last post Aug 18, 2006, 12:22:14 PM
by 4RnrRick
Last post Mar 10, 2010, 08:54:02 AM
by Rocksnail
Last post Feb 26, 2016, 09:20:14 PM
by T2crawlfun
Last post Jun 05, 2022, 09:07:44 AM
by supermoto917
