May 18, 2024, 04:43:38 PM
Welcome Guest, Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Store
Calendar
Members
View the memberlist
Search For Members
Login
Register
All
Current Board
Current Topic
Technical Discussion
Engine
Diesel Talk
(Moderator:
Topic:
Turbocharger
Pages: [
1
Go Down
Print
Author
Topic: Turbocharger (Read 1400 times)
cavey
Rock Crawl'n
Turtle Points: 496
Member since Oct '03
Turbocharger
on:
Oct 17, 2021, 04:46:35 PM »
I ordered a new upgraded turbo from AXT in Melbourne , good for 26psi , hiflowed , billet compressor wheel, 360 deg thrustbearing , boost is suppose to come in at lower rpms
Logged
OVRAROK
likes this
own a 1989 LN106r diesel with a 1KZ-T 3 litre turbo diesel bolted to a imported R151F gearbox with snorkel Rancho springs & shocks & Detroit lockers F & R & 11x 32 cooper sst ultimate dual transfer cases 130 litre fuel tank full floating disc brake rear end
cavey
[OP]
Rock Crawl'n
Turtle Points: 496
Re: Turbocharger
Reply #1
on:
Dec 05, 2021, 03:48:24 PM »
I spent the last week removing the old turbo and installing the new one ,I also moved the exhaust pyrometer out of the EGR blanking plate and drilled and tapped a new hole about 1 1/4" from the turbo mounting flange then put it all back together , the worst job was reconnecting the turbo oil supply to the engine , took it for a spin late saturday afternoon , max EGT temp was 420 degrees Celsius and power was down heaps boost was 8 psi , i tested the wastegate on the bench earlier in the week to see what pressure it opened at, and it started to open at 12 psi and fully open at 15 psi , so I came to the conclusion that the engine is running lean , ie the new turbo is supplying more air than the std turbo , now the performance is only just better than a N/A engine , because I have had the pressure hose to the boost compensator come off before whilst driving and it would manage 7 psi and 360 degrees EGT , so I need to supply more fuel , I didnt want to adjust the main fuel screw ,as the fuel is correct off boost, so I took the Diaphragm and fuel pin out of the boost compensator ,to see in which position the conical ramp on the pin was ,as all the ones ive seen the conical ramp is eccentric to the pin, so you can rotate the pin and give the engine more fuel under boost, but guess what , my pin is concentric , so i have to see if I can get an eccentric pin
Logged
Gnarly4X
Gold Turtle Award
Turtle Points: 5134
Member since Jun '16
4-wheeling vicariously.
Re: Turbocharger
Reply #2
on:
Dec 05, 2021, 04:57:21 PM »
Hey cavey....
What effect does ignition timing have on tuning for AFR and boost??
Gnarls.
Logged
1986 XtraCab SR5 22RE 5speed W56B, ~16,000 MI after break-in, DIM (Did It Myself) rebuilt engine - .020" over, engnbldr RV head, OS valves, 261C cam, DT Header.
https://imgur.com/oACTHTR
cavey
[OP]
Rock Crawl'n
Turtle Points: 496
Re: Turbocharger
Reply #3
on:
Dec 07, 2021, 04:57:05 PM »
as far as I know , bugger all, timing will give you more power if the pump is advanced, ie turned opposite direction to engine rotation , with in reason , AFR is controlled by fuel settings , to be done properly you stick a gas probe up the tailpipe whilst on the dyno and adjust from the reading you get given
Logged
helipilot77
The 1.5K Club
Turtle Points: 1018
Member since Jul '12
Seattle, WA
Re: Turbocharger
Reply #4
on:
Dec 08, 2021, 04:32:58 PM »
I’m planning to install an O2 sensor in my exhaust for tuning purposes.
Logged
& custom 3" S.S. dump pipe, R-151f transmission, marlin dual ultimate transfer cases w/ triple shifter, SAS, 35's
https://board.marlincrawler.com/index.php?topic=98969.0
-1984 SR5 Tercel 4wd wagon bone stock - given to my nephew
https://board.marlincrawler.com/index.php?topic=100547.0
-My front axle service write-up
http://board.marlincrawler.com/i
cavey
[OP]
Rock Crawl'n
Turtle Points: 496
Re: Turbocharger
Reply #5
on:
Dec 24, 2021, 05:57:56 AM »
So I ordered a boost pin from the UK to suit a Land Rover TDI300 which cost about $50 Aud but doesnt get here until the 4-1-2022 , so bugger it , ill have ago at turning one op , which I machined out of a L series head bolt because the pin is 11mm diameter, i made the cone eccentric to the rest of the pin by 1.5mm or .060" off center, and I also rotated the starwheel another 1/4 of a turn clockwise and put it back together
I now have to keep an eye on EGTs as i think i could easily surpass 600C , the off boost acceleration is fantastic, floor it in 2nd and it will break traction on 1 wheel till the detroit stops it , and it has now more power than before with the old std turbo , as i can maintain the speed limit (110kph ) up a hill which i drive regularly , where as before it would drop back to 97kph at 12psi, and now it barely makes 10psi , so it still isnt getting enough fuel , but I will put up with it for now , as i want to visit friends in Newcastle ,NSW in june and ill get it tuned properly then as there is no one capable in tasmania
also today installed a rebuilt rear T case with new 23 spline 4.7 gears inside
Logged
helipilot77
likes this
helipilot77
The 1.5K Club
Turtle Points: 1018
Seattle, WA
Re: Turbocharger
Reply #6
on:
Dec 30, 2021, 03:14:45 PM »
Very nice work Cavey. If this work out for you I would be interested to get the dimensions for that eccentric pin.
Logged
cavey
[OP]
Rock Crawl'n
Turtle Points: 496
Re: Turbocharger
Reply #7
on:
Jan 08, 2022, 03:18:02 AM »
well the new landrover boost pin arrived but it doesnt fit, the original pin measured 10.96mm diameter and the landrover part measures 11.90mm and it is very hard , too hard to machine but all the lengths look to be correct , you would think that all Bosch VE pumps would be the same, or maybe it is a landrover thing, so back to the lathe again and turn up another pin , but this time i will mill the taper in the mill of course , blank pin made waiting to be milled , also went shooting last weekend ,fuel economy was 13.1 litres per 100kms which is better , used to be 13.5, have booked the ferry and a diesel tuning shop, Berrima Diesel for D Day (6-6-2022)
the picture shows at the rear the original pin , center ,landrover pin , and front ,new pin blank
Helipilot , I would remove your boost pin first and measure it as being a Mitsubishi part it might be a different diameter also and whilst it is out back off the spring tension by rotating the star wheel clockwise about half a turn, just watch your EGTs on hills and flat out
Logged
helipilot77
The 1.5K Club
Turtle Points: 1018
Seattle, WA
Re: Turbocharger
Reply #8
on:
Jan 08, 2022, 08:15:28 AM »
My EGT’s already get high on mountain passes.
Logged
cavey
[OP]
Rock Crawl'n
Turtle Points: 496
Re: Turbocharger
Reply #9
on:
Jan 09, 2022, 12:36:21 AM »
well you will have to back off more then!!!!!
Logged
Pages: [
1
Go Up
Print
Engine
Diesel Talk
(Moderator:
Topic:
Turbocharger
