Author Topic: The Fix Jim's Van thread  (Read 4537 times)
  • Turtle Points: 2829
  • Male Posts: 8,726
  • Member since Sep '05
Re: The Fix Jim's Van thread
« Reply #30 on: Dec 15, 2015, 01:05:35 PM »
as I am finding stuff online, I will be saving it here, so I can reference it
I think I have found for my sensor side, blk=signal, white=heater, grey=ground
OVRAROK
  • Turtle Points: 24527
  • Male Posts: 3,042
  • Member since Dec '10
« Reply #31 on: Dec 15, 2015, 01:16:22 PM »
what brand 02 sensor do you have
jimbo74 [OP]
  • Male Posts: 8,726
« Reply #32 on: Dec 15, 2015, 01:29:03 PM »
from what I have found I think it is an Ultra-Power
trying to see if I can find the OE wiring diagram right now to identify the harness wire colors
OVRAROK
  • Male Posts: 3,042
« Reply #33 on: Dec 15, 2015, 01:33:41 PM »
did you scroll down on that last link, it shows colors, but every color you mentioned was the stripe color
jimbo74 [OP]
  • Male Posts: 8,726
« Reply #34 on: Dec 15, 2015, 01:34:27 PM »
some of the oe wires had stripes, but the main colors are the ones I posted
ok, went and looked again the rear has a blue w/ black stripe, black, green w/ orange, brown w/ white
 as far as the front o2, has the same 2 white, black and gray..... the vehicle side connector is still there, I can't tell what color the wires are, but I do have the stock plug o the vehicle
ok, this might  be what I need for downstream
 http://brianesser.com/wp-content/uploads/2012/07/downstreamO2_Connector.png
« Last Edit: Dec 15, 2015, 02:17:12 PM by jimbo74 »
jimbo74 [OP]
  • Male Posts: 8,726
« Reply #35 on: Dec 16, 2015, 12:10:53 PM »
ok, so for the rear o2, does the heater care if it is positive or negative? or is it not a circuit liek that, and just needs to be hooked up?
OVRAROK
  • Male Posts: 3,042
« Reply #36 on: Dec 16, 2015, 12:23:01 PM »
if the two wires from the 02 sensor are the same color, with no distinct difference, the answer would be no, it doesn't matter
jimbo74 [OP]
  • Male Posts: 8,726
« Reply #37 on: Dec 16, 2015, 12:27:28 PM »
Well, they are on the sensor, but definitely different on the vehicle side. Since I don't have the plug though, I don't know. It was correctly wired up as a direct fit, plug and play
Toyotadon
  • Turtle Points: 371
  • Male Posts: 264
  • Member since Dec '08
« Reply #38 on: Dec 16, 2015, 12:47:13 PM »
Should be fine, since you can't tell which is which on the sensor side.
jimbo74 [OP]
  • Male Posts: 8,726
« Reply #39 on: Dec 21, 2015, 10:38:23 AM »
swapped the 4th injector with the one next to it, still getting 304 and 300 codes
the guys on the dodge forum said that the number is 5% difference, meaning my front 2 cylinders are bad, so I probably need new heads.....
still don't have the front o2 hooked up, the rear is hooked up now though
Last post Feb 27, 2006, 06:43:59 AM
by CTENG in KS
Last post May 23, 2006, 09:53:05 AM
by kneedownnate
Last post Apr 25, 2007, 02:19:56 PM
by CaseyP
Last post Jul 25, 2007, 04:53:57 PM
by JanMarie13
Last post Mar 22, 2009, 12:00:54 AM
by WHITE_TRASH
