1981/1983 fRaNkEnToY build up.
Started by 81fRaNkEnToY83, September 23, 2015, 07:07:54 PM
redneckcustoms13
Pm a shipping address. I can pop a set off and mail them to you if you'd like.
01 double cab hunting truck
06 tacoma street truck
OVRAROK
Quote from: redneckcustoms13 on October 07, 2015, 09:46:40 AM
this is a fine example of what marlin crawler is all about
81fRaNkEnToY83
That is super cool redneck. I really appreciate that. I sent you a PM.
As work on the truck continues. I had to cut a little out of my transmission  tunnel for my shift lever. There was a bunch of room left over so I made a template out of some metal flashing I had.
Have to find some better metal to make a finished one but the flashing was easy for a mock up.
You wouldn't happen to have a boot for the 4wd shift lever would you? My main boot is fine but I don't have one for the transfer case.
1981/1983 Driveway special
redneckcustoms13
I'll take a gander this evening if I do I'll toss it in the box as well.
81fRaNkEnToY83
Thanks for that.
No, I am in the upstate, up in the mountains. It rained for several days pretty bad but not flooding.  Columbia and Charleston got the worst of it I believe.
81fRaNkEnToY83
Probably going to get some seats out of a 99' Honda Civic tomorrow. $40 for the pair. Should go in ok, yes?
When I went to look at them it seems like I should just have to flatten out one of the rear mount brackets. I guess I'll let yall know tomorrow. $40 for a pair of seats, I didn't think that was too bad. And they adjust in about 6 different ways.
What is the bolt pitch and thread for the seat holes on an 83'? Anyone know? I don't have one to match up.
redneckcustoms13
I think 10mm 1.25 but don't quote me on that. It's whatever all toyota bolts are that have a 12mm head on them.
Goodluck with the seats. I got some from an early 90s accord and they were too big no matter how I built brackets I couldn't comfortably set in them. And I'm only 5'9.
81fRaNkEnToY83
#37
Talked him down to $30 for the pair. Still have to pressure wash them. I hit  some of the grease spots with some stain remover. They should clean up nice.
1999 Honda Civic. I should be able to make these brackets work with a little modification. Rough fit is fine.
81fRaNkEnToY83
I think I am going to go with a gunmetal plastidip paint job with anodized bronze Mickey Thompson classic II's (I already have them though they are not on the truck now). It may be a while before I get there, but I think that that is an easy driveway paint job that might not look too bad. I have a buddy who has the spray gun already. I figured two gallons for the body and one for the wheels.
This truck is consuming every ounce of thought I can muster. I feel like a 13 yr old boy who just fell in love for the first time. I just like to hang out with it, tinker with it, think about what is next to come.
81fRaNkEnToY83
I also need to make some door panels. I thought about laying up some fiberglass over a piece of thin plywood or pegboard. I'm looking for ideas right now. I do not want diamond plate, I already know that, so I think fiberglass is the way to go.
OVRAROK
I made mine in my 84 with black abs plastic, will get a pic when theres more sunlight tomorrow
81fRaNkEnToY83
Cool. Hadn't thought of that. I'd like to see pics.
redneckcustoms13
I'll be making some for my 83 soon bur trying to duplicate factory as close as possible unless I can get some perfect factory brown ones.
LittleSteve
Quote from: redneckcustoms13 on October 09, 2015, 10:09:53 PM
Hardboard and 2mm foam covered in vinyl effect plastic, upholstery glue it all together...
Imma make a tool to follow the original lines in the door and press them in, thats the plan anyhow
Refusing to fit in or comply.
Easy is not worth anything.
OVRAROK
sorry it took a day, I couldn't get tapatalk to work
Sent from my HTC One_M8 using Tapatalk
81fRaNkEnToY83
That looks pretty good. Where did you get the sheets of plastic?
81fRaNkEnToY83
Big step today. I was able to move the truck under its own power. Thanks to my boy (8) who helped me bleed the clutch. I can't seem to get the brakes to bleed right. We fooled with it for about 2 hours and I still have no brakes. I swapped boosters and master cylinders a few times and still have no brakes.
Anyway. I moved it around the driveway.
OVRAROK
Does it have a lspv under the bed, did you bleed it last, I can't remember where I bought plastic, most likely Lowe's or home depot
81fRaNkEnToY83
I removed the lspv from the truck when it was running.
Bleeding brakes with an 8 yr old may not be the best idea anyway, haha.
I think the master cylinder I started with had gone bad. I swapped the boosters and masters from both but ran out of time with the final combination. When I gat back to it, if I can't get it to work, I will get another master and see if that is the problem.
81fRaNkEnToY83
 :crazy: I have been working 6, 12's for the past few weeks. No time to do anything with the truck. Hopefully we will be done soon and life will go back to "normal".
