Author Topic: Advice on CV or Single Cardan  (Read 1428 times)
SqWADoosh
  • Turtle Points: 10966
  • Male Posts: 2,417
  • Member since Oct '14
« on: Aug 16, 2015, 07:15:03 PM »
Got some pics of my current angle situation after putting these duals in. Am I alright using CV front and rear with these angles?
Front diff angle:
Front output angle:
Rear diff angle:
A drawing of the measurements and angles. Thanks to Helipilot for the idea. He did one for me that I scribbled on so much that I decided to re-do it and keep it clean so I could read it when it came time to speak to the two drive-shaft companies.
Via my build thread. I am looking for advice on whether to run CV or Single Cardan shafts with the angles I have.
toyodaaddict
  • Turtle Points: 399
  • Male Posts: 1,145
  • Member since Sep '08
Re: Advice on CV or Single Cardan
« Reply #1 on: Aug 17, 2015, 10:01:07 AM »
If you where running a non cv shaft in the rear before the duals I'm about %100 sure your going to have to rotate your pinion up. You want you pinion 2* under the slope of the shaft with a cv, forget about the tcase flange.
For the front I'm going to say you would want a standard u joint shaft (non cv). I'm basing that guess on the height of your rig and the fact your running duals. I could be wrong though.  Good luck
SqWADoosh [OP]
  • Male Posts: 2,417
« Reply #2 on: Aug 17, 2015, 10:54:38 AM »
Dingman asked Jesse about my angles for me. He said I need to take some string from flange to flange and measure the angle on that as well. Going to do that after work. I just heard back from Fleetpride and they already have my rear cv all done. Just a matter of when zippo has time to bring it back up to me.
Last post Sep 16, 2004, 11:52:17 PM
by conflict
Last post May 09, 2007, 09:18:05 PM
by Duffil
Last post May 25, 2007, 12:20:30 PM
by blackdiamond
Last post Feb 20, 2011, 03:15:22 PM
by hi on lux
Last post Feb 24, 2012, 12:52:27 AM
by Danny de Bont
